03-21-2017, 08:43 AM | #976 |
Happy to be here
Re: 85 GMC Sierra "Scarlett"
Last night my work in the shop was limited but I had just enough time to mock up the www.7387chevytrucks.com kick panel pods.
These pods will house @kickeraudio #ksc650 6.5" #coaxial speakers. They were designed by Chris Lucas of ensure precise fit and clearance for the E brake. I attached them to the kick panels first using the factory mounting holes. That allowed my to mark the correct location for the speakers. With the alignment dialed in I mounted the retainer rings and marked for the speaker hole. I drilled and large pilot hole and cut the opening with a small air saw. I cleaned the cut with coarse paper and slipped the speaker in place. I reinstalled the assembly to ensure everything cleared Once the passenger side is completed I will line the pods with Silent Coat sound deadner to seal the enclosure and prevent any rattles. Eventually these will be dyed Napa red to match.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-24-2017 at 12:31 PM. |
03-21-2017, 09:53 AM | #977 | |
Congratulations on a successful showing at LST! And I am enjoying the next evolution of Scarlett+Kicker.
Per this: Quote:
03-22-2017, 09:47 AM | #978 | ||
Happy to be here
Per the Admin at Nasty Z-28 Quote:
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-22-2017 at 11:18 AM. |
03-24-2017, 09:43 AM | #979 |
Happy to be here
Last night i put the the finishing touches on the www.7387chevytrucks.computer kick panel pods install. These pods were redesigned by Chris Lucas to ensure clearance of the E brake. They are very well designed but did require minor trimming on one to fit to my satisfaction.
The pods are injection molded and come with a nice textured finish. To improve sound projection I added a layer of @silentcoat sound deadner to the back side of the pods and front of the kick panel. The Silent Coat was very effective at eliminating any chance of resonance from the panels or pods and will greatly improve the performance of the @kickeraudio 6.5" coaxials. Once I was happy with the fit, I dyed everything with several coats of SEM Napa red. I am very pleased with the pods and can confidently say they are the best I have used to date
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-24-2017 at 10:34 AM. |
03-27-2017, 08:30 AM | #980 |
Happy to be here
Chris and I worked on the @kickeraudio install this weekend. He focused on wiring while I built a mounting plate for the @kickeraudio 3.5" #coaxial speakers for the center channel.
We decided to inspect the factory audio harness so Chris pulled it from the dash. It was in good condition so he wrapped it up and routed to fit our needs. The Kicker component system will incorporate 2 sets of 3.5" coaxials in the dash. One on each corner, and a pair in the center to emulate a center channel. To accommodate the center speakers I had to make a mounting plate. I started the design by creating a template. Once the template was fine tuned for fit, I transferred the dimensions to 1/4" Lexan. Cutting the Lexan with a table saw is easy, but the speaker holes are a bit of a challenge. I couldn't find a hole saw the right size so I used an air saw. It's a slow process that required clean up with a die grinder but I managed a fairly clean opening. The center plate is mounted and the dash speakers are in and wired up.
03-27-2017, 01:15 PM | #981 |
Very nice!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
03-28-2017, 09:31 AM | #982 |
Happy to be here
03-28-2017, 09:35 AM | #983 |
Happy to be here
While Chris was working on the dash he replaced the corner speakers too. We had previously replaced the stock speakers, but ran out of time to finish the original install. Fortunately Kicker stepped in and supplied us with premium quality components to build the system.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-28-2017 at 11:53 AM. |
03-29-2017, 09:05 AM | #984 | |
Thanks again, back to trackin with your Scarlett improvements. I like how you are fitting the sound system to the truck, rather than cutting up the truck to fit the system. No disrespect to those that cut the truck to fit. I just like to preserve factory provisions where possible and then update the components where technology has advanced, or the factory had to compromise to be cost-competitive. Last edited by LT7A; 03-29-2017 at 09:15 AM. |
03-29-2017, 11:15 AM | #985 | |
Ken, I had a problem with my corners speakers rubbing the dash pad, had to trim the ears a little and remount them from the bottom edge of the brackets. Dash pad was actually limiting the speaker cone movement, sound was much improved after the relocation.
Desert |
03-29-2017, 11:43 AM | #986 | ||
Happy to be here
Wait to you see how I am mounting the KMC20 controller. I was able to come up with a method that doesn't require cutting the dash or the stock bezel.
03-29-2017, 11:47 AM | #987 |
Happy to be here
I'm going to take a look at that. When I removed the other speakers I noted that the cone was a tiny bit distorted. I'm thinking the dash pad might have been touching. It may have happened during the pad install too, but I'm going to verify clearance on the new speakers. Surprisingly, the Kicker speakers are lower profile even though they are coaxial.
03-29-2017, 03:34 PM | #988 | |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
03-29-2017, 04:54 PM | #989 |
check out my build thread Ol Blue post #51. I went thru the same thing. Just got done mounting my dash and there was plenty of room. I put a few thin strips of clay to see how close the dash would get to the speakers and it never touched them or the clay!
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
03-29-2017, 08:05 PM | #990 | |
Happy to be here
03-30-2017, 12:13 PM | #991 |
Happy to be here
One more piece of the @kickeraudio puzzle fits in place. Last night I finished making the mounting panel for the bass control and usb media port.
The Kicker Hideaway 8" sub includes a remote mount gain control. It's a set it a forget it feature most of the time, but occasionally you might want a bit more bass. I decided to mount it in the glove box to be accessible yet hidden when not in use. I had some extra space so I added a charging and data port as well. The port will allow fast charging of any electronic gadget and USB input as well. The USB port will be connected to the KMC20 processor in the event you want to play stored music from a device that does not have Bluetooth. This is perfect for a demo list stored on a thumb drive.
03-30-2017, 12:18 PM | #992 |
Happy to be here
Here's a sneak peak of how I mounted the KMC20 display without cutting he factory bezel.
I will post the finished product later.
03-30-2017, 01:19 PM | #993 |
Love this build. Curious, did you ever finish the tailgate band?? I've been thinking about it every time I look at mine...
-1987 GMC Sierra Classic 5.3 LS - -2001 Toyota Camry 175k - |
03-30-2017, 08:06 PM | #994 |
Happy to be here
Thank you sir. No, I haven't touched the tailgate band. I'm still looking for a good solution besides spending several hours stripping, sanding, and clearing.
03-30-2017, 11:17 PM | #995 |
03-30-2017, 11:47 PM | #996 |
I used some ridiculously strong rare earth magnets to attach my front speakers "under" the metal opening of the speaker areas. I used GM Bose automotive speakers from a CTS. I used (2) center loudspeakers and a tweeter at each dash corner-the sound is incredible when pushing the 1.5 ohm speakers using an old JBL amp pushing the BOSE speakers in series @ 2 ohm load! I've said it before-push the BOSE speakers with a good amplifier and they come alive!
03-31-2017, 09:31 AM | #997 | ||
Happy to be here
03-31-2017, 11:51 AM | #998 |
That's how i did mine and yes, plenty of room.
03-31-2017, 12:31 PM | #999 | |
This is the only pic I could find, not the best angle. But you can kind of see that the cone of the speaker isn't even seen, because it's below the bracket or flush with the bracket.
03-31-2017, 07:03 PM | #1000 |
Happy to be here
Yesterday morning I started early and finished the @kickeraudio #kmc20 display install. After lots of contemplation I designed a way to mount the dusplay without modifications to the bezel or dash.
Previously I had made a template to cut out a piece of 1/16" textured abs to fill the cavity on the bezel. I attached it with thin double sided tape while I marked and drilled a couple of extra holes in the display mounting tab directly over the original radio holes. I made a small backing plate out of 1/8" abs scrap to attach from the backside. Once I was comfortable that this would be secure I took it all apart once again and repeated the process on the new bezel supplied by Brothers Truck parts.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-31-2017 at 10:48 PM. |
