Old 03-23-2017, 12:36 PM   #1
animals speed shop
64-66 what rear tank are you using ?
What is everyone using for bed mounted tanks these days ?
I have a couple of trucks to do a 1960 a 1962 and 1965 all short boxes so i would like to start buying all the same tanks . What is everyone using for carburetor and LS builds ?
Thanks guys
animals speed shop is offline   Reply With Quote
Old 03-23-2017, 02:18 PM   #2
cp_66_c20
cp_66_c20's Avatar
Re: 64-66 what rear tank are you using ?
I have a 30 gal tank and I spent 400 is for every thing.
Here is my 5.3 ls tanks swap part list (also works for carb motors)
●87-91 fuel tank $94.90
● 87-91 31 gal tank straps $28.75
● EFI 87-91 fuel tank sender $80.00
● high pressure pump $70.00
● fuel lines $50.00
● high pressure filter $20.00
*Total spent = 343.65
cp_66_c20 is offline   Reply With Quote
Old 03-23-2017, 03:24 PM   #3
verdell
verdell's Avatar
Thanks guys
The '60-'62 frame is wider than the '65. I used a 22 gallon '78 chevy van tank, straps and sending unit because it doesn't hang as low as the blazer tank and fit's pretty well. I'm planning on swapping in 5.3 L33 in the near future and will use the same tank with an OEM in tank fuel pump. There's probably a couple of threads that would be helpful as well..
verdell is offline   Reply With Quote
Old 03-23-2017, 05:29 PM   #4
scoot_mcgrute
LMC top fill tank on my 66 stepside
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 03-23-2017, 05:35 PM   #5
Chevystep
Really? No 1969 Camaro tanks with a license plate filler? Still contemplating doing this with my 66 for the reason that it's a stepside and I don't want fender or bed filler cap. Tucking it up as tight as I can seems doable without a bunch hanging down, love the license plate filler if it can be done, but wonder if "fuel slosh" toward the filler cap is a problem...I guess I could add a baffle to a new tank...
Chevystep is offline   Reply With Quote
Old 03-23-2017, 06:13 PM   #6
bbluma
How did the LMC tank fit? i heard you have to do some adjusting and all. But that might have been for the side fill. Thinking about getting the LMC Top fill myself and was curious.
bbluma is offline   Reply With Quote
Old 03-23-2017, 07:02 PM   #7
ol_skool_chevy
ol_skool_chevy's Avatar
1966 mustang tank fits nice in back........
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 03-23-2017, 07:24 PM   #8
63frankintruck
Is it possible to use the mustang tank and fill from tailight?
I want to incorporate the tail light for fill area.
63frankintruck is offline   Reply With Quote
Old 03-23-2017, 10:33 PM   #9
namloc
namloc's Avatar
Thanks guys
First generation mustang .Using a stewart warner sender kit for gm gauge.Worked great .And $"s spent are low.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 03-23-2017, 11:43 PM   #10
65Gregg
65Gregg's Avatar
53-54 Chevrolet passenger tank from Tanks Inc, comes baffled for EFI use.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 03-24-2017, 07:14 AM   #11
zach_carver
zach_carver's Avatar
Im using a Boyd welding tank in my 65 with my LS2. Quality and fitment is top notch! Not cheap but excellent tank. Im very pleased with it. Its a top/bed fill.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 03-24-2017, 09:27 AM   #12
scoot_mcgrute
Fit great, no modifications needed
1966 Army Truck
Old 03-24-2017, 09:35 AM   #13
scoot_mcgrute
This is the direction I wanted to go with my step side, a few have done it, but I caved and got the top fill tank from LMC. I like the hidden fuel filler as I have yet to see a filler setup that I like on a step side. The fuel sloshing back was a concern for me, the cars do it all the time and that's not what I wanted so that's mainly why I went top fill.
1966 Army Truck
Old 03-24-2017, 10:53 AM   #14
Chevystep
http://www.67-72chevytrucks.com/vboa...d.php?t=652774
see post 7 and 20....
Old 03-24-2017, 02:18 PM   #15
nimrod
nimrod's Avatar
'66 with an LT1 here. I have not regretted buying Boyds at all!
nimrod is offline   Reply With Quote
Old 03-24-2017, 04:44 PM   #16
animals speed shop
That sounds interesting...will check that out
Old 03-24-2017, 05:05 PM   #17
animals speed shop
Boyd tanks look great and I bet they work great .....A little steep for some of my customers who want to do a budget build . I was just looking at a 85 blazer tank that i was thinking of building a neck to make it a top fill. Anyone try that before ?
Old 03-24-2017, 07:28 PM   #18
63frankintruck
(Can anyone tell me what type of tank are people using for the tail light fill?)
Old 03-24-2017, 08:33 PM   #19
AcampoDave
AcampoDave's Avatar
I used the one in post #6 and was pleased with it.
AcampoDave is offline   Reply With Quote
Old 03-24-2017, 10:08 PM   #20
'63GENIII
'63GENIII's Avatar
Think I spent 50$ used, clean with the filler neck, locking cap, straps and skid plate. I think it is the bigger of the Blazer tanks - 33-35 gal. I think there may have been a smaller one around 25 - 27 gal. that doesn't hang as low. I actually bought a sending unit that I had to return because it was 4" too short and wouldn't touch the bottom.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-29-2017, 08:53 AM   #21
richards72chevy
richards72chevy's Avatar
● fuel lines $50.00
Will the 87-91 sending unit work with the factory fuel gauge?
richards72chevy is offline   Reply With Quote
Old 03-29-2017, 12:04 PM   #22
cp_66_c20
cp_66_c20's Avatar
I have autometer gauges. what I did was drill out the rivits to the sending unit and attach a sending unit with the correct ohms to my gauge an wire it in where the old one was. I also instslled a walbro 255 and wired it in to the existing harness. You can do the same and it will work. It may be off a little but nothing is perfectly accurate. I will try to upload pics later tonight to give you an idea of what I did.
Old 03-29-2017, 01:44 PM   #23
The Rocknrod
Moderator
The Rocknrod's Avatar
Doc's Kuston Tanks
https://www.southernrods.com/fuel-sy...fuel-tank.html
http://www.aplusrodandkustom.com/ind...16/prd2416.htm
Old 03-29-2017, 02:03 PM   #24
richards72chevy
Thank you Cp_66_c20. What is a walbro 255?
Old 03-29-2017, 02:12 PM   #25
Rod Stryker
speaking of 66 mustang tanks, anyone think this is a good pairing with a 5.3l LS engine? https://www.summitracing.com/parts/a.../model/mustang
Rod Stryker is offline   Reply With Quote
