Old 03-23-2017, 11:15 PM   #301
daddyjeep
daddyjeep's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Originally Posted by 75Dually View Post
I just went through you entire build. That truck is going to be fun! I really like the hood. Good to know there is another guy out there who likes to shape metal!
Can't wait to see it on the road!
I'm certaibly learning as i go, but I am enjoying building something unique.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-27-2017, 12:46 PM   #302
daddyjeep
daddyjeep's Avatar
I finished sound deadening the floor and the back of the cab this weekend as well as insulating it. I was really happy with how the Home Depot duct insulation worked out. I sprayed the floor and the back of the insulation with 3M super 77 and sealed all of the seams with aluminum tape.
[IMG][/IMG]
[IMG][/IMG]
After the insulation I started covering everything with some heavy felt I had in the shop. I ran out of spray adhesive so I didn't get it completely done, but couldn't resist throwing a seat in there for the first time in a year.
[IMG][/IMG]
04 1500 crew cab
Old 03-27-2017, 01:16 PM   #303
NastyBuzzard
NastyBuzzard's Avatar
Looking good! Do you have an approximation of how much of the sound deadener you used?
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 03-27-2017, 02:01 PM   #304
daddyjeep
daddyjeep's Avatar
I used 4 rolls on the floor and back of cab, so 50 sq/ft. I will need at least two more to do the doors and some of the roof. I don't think I am going to 100% cover the roof. The 100 sq/ft you had mentioned before should be about right and would allow for a little more coverage on the roof.
04 1500 crew cab
Old 03-29-2017, 02:39 PM   #305
DieselRat
Hey looks familiar haha! Funny how all that room goes away quick when the seats are in!
54 GMC OM617 diesel swap
http://67-72chevytrucks.com/vboard/s...d.php?t=588827
87 Chevy Crew Cab Cummins
http://67-72chevytrucks.com/vboard/s...d.php?t=711157
DieselRat is offline   Reply With Quote
Old 03-29-2017, 03:33 PM   #306
MTCK
MTCK's Avatar
Looking good! I used 100 sf on mine and it did the whole floor, parts of all the door skins and about 2/3 of the roof.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 04-02-2017, 11:52 PM   #307
daddyjeep
daddyjeep's Avatar
For the first time since I owned this truck, it has seats and seat belts. It is starting to come along.
[IMG][/IMG]
I also finished painting up some new inner fenders. Krylon satin black for under the hood and duplicolor bed armor for the tire side.
[IMG][/IMG]
Finally, a local guy posted a set of hardly used headlight bezels for $20. Obviously I had to bring them home.
[IMG][/IMG]
04 1500 crew cab
Old 04-04-2017, 01:13 PM   #308
Shucks
Shucks's Avatar
Looking really good!
C H E V R O L E T
Check out my build thread!
Shucks First Build
Shucks is offline   Reply With Quote
Old 04-04-2017, 09:27 PM   #309
daddyjeep
daddyjeep's Avatar
That tan felt was bugging me and since I am not buying carpet right away I had to do something. I had some Duplicolor vinyl and fabric paint so I shot some on it. I like it much better now.
[IMG][/IMG]
04 1500 crew cab
Old 04-10-2017, 12:52 PM   #310
daddyjeep
daddyjeep's Avatar
I cleaned up my threshold pieces and sprayed some more satin black Krylon on them. The old door seals are going to have to do for now so they got installed as well. I also spent a couple hours cleaning up and painting my battery tray. At least all of the oil coating it kept it from rusting.
[IMG][/IMG]
[IMG][/IMG]
I checked my local salvage yard for a better grill and came up empty, imagine that, so I decided to learn how to plastic weld. My grill was pretty busted up and was only being held in place with one screw. The top rail was in three pieces and both bottom outer tabs were broken off and gone. Surprisingly it worked out really well. I managed to completely repair the top rail. I had to re attach every vertical piece as well. I cut up my old headlight bezels for filler material and completely rebuilt the lower tabs.
[IMG][/IMG]
It might not be pretty, but it gets the job done.
04 1500 crew cab
Old 04-15-2017, 07:29 PM   #311
daddyjeep
daddyjeep's Avatar
Either I really enjoy building stuff or I'm cheap. Either way I have taken pieces form a couple of discarded exhaust systems with a few new pieces and built a complete dual exhaust system. I made a cross over pipe from the passengers side so they both run down the drivers side. I still have a couple mounts to add, but am pretty pleased with how it came out. Don't mine the shiny tips. They will clean up some at least.
[IMG][/IMG]
The mufflers are cherry bomb turbos, so I had to paint them red.
[IMG][/IMG]
Now I just need to fire it up and see how it sounds.
04 1500 crew cab
Old 04-15-2017, 11:17 PM   #312
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I just read through your build and I'm loving it. Subscribed so I can watch the progress
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-15-2017, 11:19 PM   #313
daddyjeep
daddyjeep's Avatar
Thanks for following along Blue.
04 1500 crew cab
Old 04-15-2017, 11:41 PM   #314
Ol Blue K20
No problem, you're doing some awesome work. I'm going to enjoy this build
Dale
Old 04-15-2017, 11:55 PM   #315
whitels1
whitels1's Avatar
Doing some great work man!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 05-10-2017, 12:36 PM   #316
daddyjeep
daddyjeep's Avatar
Not much to update...too much other stuff going on. I did manage to get the front end mostly put back together and was happy that my heavy hood stays up all by itself.
[IMG][/IMG]
I also buttoned up my exhaust...for now.
[IMG][/IMG]
I sprayed some satin black inside the tips and worked on the outside for about 3 minutes with scotchbrite. It looks good enough for right now. I was a little disappointed when I got the truck fire up. Those Cherry Bomb turbos are much quieter than I hoped. I don't want it to be obnoxious, but a little rumble would be nice. I will address that later...remember, it just has to function right now. The other issue I encountered when firing it up is my facet fuel pump is having a hard time getting the fuel to the carb. I had it running by manually filling the bowl. I have not spent much time trouble shooting that yet. I am going to remove the line from the carb and check that filter and run the pump with it disconnected for a bit so I know I have a good prime.
The truck was supposed to be on the road by now, so it is crunch time. With any luck it will be ready this weekend. It needs to drag the Jeep toe the Bantam Jeep Festival on June 7th and I really need some driving time before then to identify any issues.
04 1500 crew cab
Old 05-10-2017, 01:04 PM   #317
whitels1
whitels1's Avatar
I'm sure you will get it figured out. Have fun at jeep fest!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 05-11-2017, 11:50 AM   #318
MTCK
MTCK's Avatar
So close! Hope your shakedown goes well.
-Marcus
Project Plow Truck
Old 05-11-2017, 05:36 PM   #319
DieselRat
coming along nicely! I used that vinyl and fabric paint for my door carpets and such and while it took a lot of it to officially 'dye' it, it came out great and is still soft like carpet should be.
Old 05-16-2017, 12:30 PM   #320
daddyjeep
daddyjeep's Avatar
Well...another weekend gone and nothing to show for it. I spent the weekend keeping the wife happy since it was mothers day. Enough of that, I have a truck to finish. There were town wide yard sales that the wife wanted to go to so I did at least pick up a set of 6x9 pioneer speakers for the truck, in carpeted boxes for $15. I also picked up a new inlet filter for the quadrajet so hopefully once I get a good prime this thing will run as it should.
04 1500 crew cab
Old 05-16-2017, 02:57 PM   #321
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm glad to see I'm not the only loosing out on project time to wife projects. Nice score on the speakers and good luck with getting it ready to tow your ride!
Ryan
1969 Chevy milk truck
Old 05-16-2017, 08:15 PM   #322
daddyjeep
daddyjeep's Avatar
Well, it runs. It revs great, idles great, recovers from revs just fine, but it smokes quite a bit. It will hopefully get better as I run it. It has sat for 12 years after all. Can anyone make me feel better because they had similar experience with a motor that sat for an extended period? There is no coolant in the oil.
Lets see if my video works.
04 1500 crew cab
Old 05-16-2017, 08:43 PM   #323
daddyjeep
daddyjeep's Avatar
https://youtu.be/vBT_u-MVZUM
Lets try it this way
04 1500 crew cab
Old 05-17-2017, 02:03 AM   #324
MTCK
MTCK's Avatar
I can't say I've had that specific issue, but if there isn't an obvious mechanical clatter I'd go run the wee out of it. Valve guide seals, rings or ??? PCV working properly? Congrats on getting her running!
-Marcus
Project Plow Truck
Old 05-17-2017, 02:29 AM   #325
68Timber
I know the pieces fit
68Timber's Avatar
I wouldn't worry about it until you've run it on the road for a while. Sounds good though!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
