#751 |
Re: 70 Blazer Frame Off
call me old school, but I thought she looked fine with the boobs she had. JMHO, hope this part doesn't make the book
#752 | |
I'm trying....
![]() Join Date: Oct 2013
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#753 |
wonder if we should do a poll, stock over modified, I think stock has more value
#754 |
My experience at Barrett this year, ls swapped really nice blazers 60-70k, stock but nice 30-45
1972 Dark blue, Cst, Highlander |
#755 |
![]() Join Date: Jun 2014
I cant tell you from my generation perspective (Im 27) tastefully modified is probably a lot more desireable. Especially since 90% of people my age never owned a carb'd engine or 4 wheel drum or manual steering vehicle in their life. when i first got my K5 i told my wife to pull the choke out and her response was.. "choke like on the lawn mower? why the hell does your truck have that?" LOL
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
#756 | |
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
#757 | |
BTW, I'm 67
#758 |
I'm 28 and I'd have to say if it was all original and numbers matching I'd keep it original down to the spark plugs. Luckily my blazer was no where near original so I decided to try the ls swap. But I am taking the truck back to original looks including carpet and am radio. Now I did see an all original blazer down to the radiator hose clamps and I thought that was the coolest thing!
Anthony 1972 K5 4x4 1969 Camaro SS 1987 Grand National 1985 Cutlass |
#759 |
My $0.02 which doesn't buy you much these days.
A totally numbers matching, longstanding collectors model is generally going to get the bigger money restored to original. ie) A COPO model or a Tri-power vette, or a Tri-power GTO, or, or... I don't think Blazers are in that longstanding "collectors" bracket yet. Maybe someday. They sure are gaining popularity over the last decade. This particular Blazer had a gorgeous restoration and I reference this thread from time to time while working on my own. I think it was an exceptional job, however, many items on it already were not factory correct or original so it was to some degree "resto-modded" already. How far one goes with that and what is acceptable is to each their own. The value is what the last person paid for it.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#760 |
I love an all original numbers matching one too, but at the end it depends what type of vehicle you want. I've had all that stuff when I was younger, and as cool as it was, I've outgrown it. The way I look at it, and engine/trans swap will always be reversible as long as nothing gets chopped up. I think collectors down the road will see this, and I don't think it will reduce the value too much if anything. The newer engines and transmissions are sooooo much nicer to drive and I can't really see one negative in them over the old engines. The 20+ MPG is nice too !!
#761 | ||
I'm trying....
#762 |
I'm trying....
Eric's son (OLDYELLOWSUN on the board) messaged Delmo and he sent him this. It ain't ugly.
#763 |
That does look pretty good!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#764 |
Registered 1971 K5
I see the Blazer around on Instagram. No matter what is done to it to try and change it a little. It was perfect the way it was before it sold and I'm no original, stock type of guy what so ever. To me that Blazer is and always will be IronCanine's Blazer.
#765 | |
I'm trying....
#766 |
2WD Jimmy
![]() Join Date: Mar 2005
#767 |
I'm trying....
Boy she sure still takes a pretty picture. Looks like she might be available.
https://www.instagram.com/p/BTC9aXuljZC/
#768 | |
I must be bright, Daddy called me sun--- http://67-72chevytrucks.com/vboard/s...d.php?t=703733 Last edited by oldyellowssun; 05-09-2017 at 09:32 PM. |
#769 |
#770 | |
My son's 1970 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=703733 Iron Canine's Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 Iron Canine's little girl's tractor http://67-72chevytrucks.com/vboard/s...d.php?t=766665 1969 SWB 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=786335 |
#771 |
I'm trying....
This is appointment television.
#772 |
#773 |
When does it sell, or has it already?
#774 |
I'm trying....
#775 |
I should let you know your build and color choice are wrecking havoc with my ability to choose a paint color
![]() Soooo, thanks a lot ![]() But seriously, it's an amazing/inspiring truck! |
Tags |
1970, blazer, k5 blazer, restoration, silver |
