Old 03-28-2017, 07:11 PM   #1
KJH90
New Gauge Cluster - Truck Wont Start
1971 Chevy C10 - Fuel Injected and does have a computer on the truck.
I just swapped the entire gauge cluster for a brand new one from Classic Industries. Hooked it all back up and go to start the truck and nothing happens.
I am not too well rounded on vehicles, just know the basics.
Any help would be appreciated.
KJH90 is offline   Reply With Quote
Old 03-28-2017, 08:11 PM   #2
samkost
samkost's Avatar
Re: New Gauge Cluster - Truck Wont Start
In Gear and not in Neutral or Park?
Don't ask how I know this
When I restored my dash cluster I dropped my steering column down to allow enough room for removal and reinstall.
Had the cluster in the dash and went to test the lights and fire up the engine.
Engine would not fire
Scratched my head for a while and then it dawned on me that the column was still unattached and the gear selector had dropped in gear.
Lifes little lessons
Good Luck
samkost is offline   Reply With Quote
Old 03-28-2017, 08:36 PM   #3
davepl
davepl's Avatar
If it's not as simple as in gear, start tracing the purple (crank) wire from the key and on through the neutral safety switch at the base of the column, from where it goes to the starter. Got to be in that wire somewhere!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-28-2017, 08:41 PM   #4
samkost
samkost's Avatar
Thumbs up Re: New Gauge Cluster - Truck Wont Start
You could be right Dave, I forgot to mention the neutral safety switch.
Old 03-29-2017, 06:33 AM   #5
KJH90
It happened to be that the gear shift was not in park!! It's funny how the little things are so easy to overlook. Well, I guess you live and learn.
Thanks again.
Old 03-29-2017, 09:19 AM   #6
67 chevelle
67 chevelle's Avatar
Do you have an ls engine , if so check your , crank wire , and 12 volt run wire , you probably pulled one off messing with the dash , next cam , and crank sensor conections , if one of those came lose it wont run either , I had one pop lose hitting the brakes hard in reverse , let us know
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-29-2017, 09:35 AM   #7
KJH90
The gear shift was not in park... Oops! After I dropped the column I forgot to put it back in park. Won't make that mistake again!
Old 03-29-2017, 12:13 PM   #8
davepl
davepl's Avatar
Good job Sam, guessing that one right off the bat!
Old 03-29-2017, 07:44 PM   #9
samkost
samkost's Avatar
Been there and definitely did that!
It took me a hour or so to figure my C10 wouldn't start in gear.
Glad your up and running KJH90
Good luck
Old 03-30-2017, 03:47 AM   #10
boynton
boynton's Avatar
We need some pictures!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 03-31-2017, 07:55 AM   #11
racerop
racerop's Avatar
Flag
racerop is offline   Reply With Quote
Old 03-31-2017, 08:19 AM   #12
undertaker72
undertaker72's Avatar
flag twice
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 03-31-2017, 08:30 AM   #13
boynton
boynton's Avatar
Lame no one here will click on that cap anyway.
1970 SWB Step-Side
