Old 03-30-2017, 03:19 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question Need a little help...
I'm trying to wire up my cargo light that was converted to a third brake light. I mounted it to the hatch not problem. However I am having a problem going through the header panel that the hatch is attached through. I thought I could snake it through the where they hinge bolts up, but that turned out to be a closed in pocket. I even drilled through the pocket, but that was a dead end also. If you look at a the third picture with the yellow arrow there is a factory bolt in the bend of the header panel. Can someone try to snake a wire up through there to the roof? I would do it myself, but I welded it up before we did the paint work, . If there is access through there, I will drill it back out, but I don't want to make any holes unless I know for sure I can get a wire up to the roof. Thanks in advance.
Hart_Rod is offline   Reply With Quote
Old 03-30-2017, 04:43 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Need a little help...
Too bad on the timing. A month ago I could have snaked a camera up there on mine:
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-31-2017, 08:20 AM   #3
Hart_Rod
Hart_Rod's Avatar
Dang, that would have really helped.
Old 03-31-2017, 09:20 AM   #4
Bigdav160
Bigdav160's Avatar
I snaked a wire through the bolt hole and it does go into the D pillar.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 03-31-2017, 10:05 AM   #5
Hart_Rod
Hart_Rod's Avatar
Will it come out the overhead with the headliner removed?
Old 04-06-2017, 10:12 AM   #6
Hart_Rod
Hart_Rod's Avatar
