#726 |
Re: My suburban's Twisted Little Sister
Hey Ian. Yup "wooden wheels" new from Bedrock Racing
I'll just drive fast and wear off the high spots. Nothing really new. Just weld grind repeat.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#727 |
Man that looks way different from the last time I checked this thread!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#728 | |
We finished off some more of the welding this week. First the passenger side fender top then the drivers side. Then we started positioning the sheetmetal so we can start tacking the top and bottom of the fender together
#729 |
Was out your way on Thursday late afternoon seen an orange 60's pickup truck in that area but not sure if you know where that is..It was. Close to Kent Bridge
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#730 |
i'm sorry to say this, but i don't think you're gonna like the truck when you're finished. might as well start converting it to diesel and i'll take it off your hands. jk. looking good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
#731 | ||
Pulled the suburban out of storage this week. It needed a new battery and a fuel pump relay. We also test fit the hood and found that we have to tweak the fender alignment a little bit.
#732 |
Both burbs are looking good!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#733 |
Burb! Burb!
Hey got an idea. Put steel wheels on it and make plywood hubcap. Something like this.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#734 |
Next time,,we were dropping a trailer off .. then picking a wrecked big truck in Windsor
#735 |
We spent the last couple of days welding the fender top to the bottom. So far we have about 2/3 of the driver side done. To break up the monotony we decided to start making the pieces to attach the piece we cut off the front of the hood, to the grille. We got the two center sections tacked in and started working on small pieces that will come next.
#736 |
Looks great Dale. So the hood will open behind the red panel?
#737 |
Looking good Dale, are you still going to use the twin C2 style lights
Getting old sucks.............but it sure beats the alternative |
#738 |
Awesome
#739 | |
Thanks Lower. Yes the hood opens behind the red panel and tilts forward
Thanks Pirate We finished welding the top and bottom of the fenders together. Then we removed the hood that we had tacked in place. Next step was to make a panel to attach the front hood section to the rad saddle
#740 |
We made the small panels that will be beside the lights. Next we cut out a section of the top of the rad saddle where the lights will go.
#741 |
Are you moving the lights up to the hood
#742 |
That's right 63 GMC headlights in the corners of what used to be the hood
We finished the modifications to the top corners of the rad saddle. We made a new top for the corners and welded them on. Also we got a little bit of welding done on the front panels. Still lots to do.
#743 |
To reenforce the front edge of the fender where the headlights will go we bent this piece. Then we tacked it in place.
#744 | |
I love this thread..... may have mentioned it before.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#745 |
![]() Join Date: Aug 2013
i have been away awhile, are those the new wood grain custom wheels?
#746 |
Can't wait to see this thing in person.
#747 |
Building it Slick with all the cool stuff.
#748 | ||
You can come by any time just let me know. Thanks Bomp. This week we did some more welding on the front panels. Also we made some panels for around the headlight buckets. One piece is welded to the fender. The other pieces are welded to the grille surround.
#749 |
We made some more progress on the headlight buckets. We made a plate for the back. Then we modified the piece the lights mount to. Then we cut two holes in the back plate. Finally we set the pieces in place
#750 |
I continue to just love this build.
Front end shaping up nicely too.
