Old 03-30-2017, 08:57 PM   #1
Slowboat
1996 Dodge 2500 wheels on 1969 C20?
Hey Folks,
I'm looking at a pair of aftermarket wheels that were used on a 1996 Dodge 2500 truck. These are 8 lug, 20" wheels, and the size is: 295/50/20
I have a 1969 C20 with a 2.5" spindle drop in the front, stock rear. Still trying to get more info about the wheels, but the seller doesn't know much. They are pretty nice looking, and I think would go ok on my C20.
Do folks know if these will fit ok? Like I said, I'm working on getting backspacing numbers, or a model number on the wheels, but wondering if I should take it further.
Slowboat is offline   Reply With Quote
Old 03-30-2017, 09:09 PM   #2
pooch
pooch's Avatar
Re: 1996 Dodge 2500 wheels on 1969 C20?
This is a good tool for checking wheel fit
http://www.roadkillcustoms.com/hot-r...#axzz4crRBHWXp
pooch is offline   Reply With Quote
Old 03-31-2017, 08:25 AM   #3
Slowboat
Thanks for the link to the wheel call. According to it they will fit, but I really need to get the details from the seller.
Old 03-31-2017, 08:56 AM   #4
Jrainman
Jrainman's Avatar
make sure you check the hole center size for the front hubs, this is where I think the problem may arise .If I remember ford ,dodge, chevy 8 lug pattern is same on certain years , but hub size on certain years tend to vary in diameter size of hub.
Jrainman is offline   Reply With Quote
Old 04-03-2017, 10:00 PM   #5
rustrunner
I think the offset on the Dodge rims are different, and you will have to use a 1 1/2 or 2 inch spacer to set the tires out where they should be.
Without the spacers the stance will look top heavy
1970 Custom Camper/20
1959 Morris Minor 1000
1953 Dodge B-4-KA
1953 Fruehauf 30' Lowboy
1928 Cat 30
1939 TORO Bullet Tractor
rustrunner is offline   Reply With Quote
