Old 04-01-2017, 12:42 PM   #326
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Time for a few more updates! Since I put in the radiator and hooked up all the hoses I figured it was a good time to run do a little carb tuning and check over everything. Good thing as after about 20 mins running i had about 1 cup of oil on the floor under the rear of the pan!
So we crawled under and yanked the pan off and took it over to the solvent steam cleaner and put a nice new 1 piece gasket in! While the pan was cleaning i decided to instal the new booster and master/prop and run the brake lines. Just a little to shiny for me but I will figure something out? lol
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 04-01-2017, 12:58 PM   #327
6t9camaro
6t9camaro's Avatar
I moved onto a little interior work since my dash pad and carpet came in from brothers. I had ordered that from lmc but it showed up in olive green that didn't match at all! So I decided to try brothers and just go blk dash pad and try their lighter colour green carpet. Carpet Green is good but they messed up and sent me a high hump carpet! So instead if returning I just put a high hump tunnel in i had kicking around (future plans anyway). My daughter is now happy as she can play and sleep in the cab while I work! lol
Build
67 Green Gobblin
Old 04-01-2017, 05:19 PM   #328
Bucky10pt
Unreal, awesome work. I just picked up a cab with new floor that I have to weld in. Your pics will surely help. Going for that patina on a 67 factory utility bed c10 like one that was at sema last yr. Keep pics coming!! Unreal talent you have for metal work
Bucky10pt is offline   Reply With Quote
Old 04-01-2017, 08:10 PM   #329
nds1968
nds1968's Avatar
Very nice work...
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 05-28-2017, 12:31 AM   #330
6t9camaro
6t9camaro's Avatar
Time for a few more updates! I decided to run the 72 EEC style tank with the vapour canister to try and cut down on some gas smells so we shall see how that works? I had the tank steam cleaned and pressure tested so its ready to go. I also tracked down the correct canister and fender bracket. Heres a few pics!
Build
67 Green Gobblin
Old 05-28-2017, 12:43 AM   #331
6t9camaro
6t9camaro's Avatar
Next up gauges! I wasn't happy with my LMC cluster since I was kicking myself for not ordering it with the vac gauge. So I returned it and ordered the one I should have got in the first place! :wash:
I also wanted to convert the amps to volts so I grabbed a similar size volt gauge (sun pro) and an old GM amp gauge and swapped the guts. Turned out pretty good as you can't even tell and works perfect!
Build
67 Green Gobblin
Old 05-28-2017, 12:45 AM   #332
6t9camaro
6t9camaro's Avatar
Back side of gauge and installed into the truck with the dash wiring complete.
Build
67 Green Gobblin
Old 05-28-2017, 03:17 AM   #333
Jason7121
Jason7121's Avatar
Wow amazing job looks great
Jason7121 is offline   Reply With Quote
Old 05-28-2017, 08:25 PM   #334
kingNothing
kingNothing's Avatar
Nice work on the truck. In a world of LS engines,love the big block. Do you remember where you got the canister? My 72 is in need of one.
Yeah' well sometimes nothin' can be a real cool hand
Lucas Jackson
kingNothing is offline   Reply With Quote
Old 05-28-2017, 10:02 PM   #335
6t9camaro
6t9camaro's Avatar
Thanks guys!
KingNothing I crossed reference the factory canister #s to acdelco #171131148 and i ordered from gm parts direct.
Build
67 Green Gobblin
Old 05-29-2017, 04:47 AM   #336
NewType72
NewType72's Avatar
Great work with the gauge swap, I'm a sucker for proper looking retrofit work
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 05-31-2017, 10:33 AM   #337
hewittca
hewittca's Avatar
Everything's looking amazing. I'm really looking forward to seeing this one finished.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 10-10-2017, 03:23 PM   #338
hewittca
hewittca's Avatar
Any updates on the build?
Old 02-19-2018, 01:07 PM   #339
ilikethewoods
ilikethewoods's Avatar
I've been on this build thread for hours...HOURS! *not kidding* Your build should be a staple of "How to build a C10"! Thanks for all of the information, lit a fire under my a$$ to get into the garage!
ilikethewoods is offline   Reply With Quote
Old 02-19-2018, 08:30 PM   #340
6t9camaro
6t9camaro's Avatar
Ahahah thanks ilikethewoods I’m glad you like the build! I’ve had to take a break from it for abit and while doing that plans have changed! When I get some time I will update to where I left off last year.
Build
67 Green Gobblin
Old 02-20-2018, 10:03 AM   #341
hewittca
hewittca's Avatar
Lookin forward to any updates. This is one of my favorite ongoing builds.
Old 03-12-2018, 09:51 PM   #342
slowcpe
slowcpe's Avatar
Just ran through your build. Was looking at projects with blending new paint and patina and found yours. Great progress so far.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 03-19-2018, 06:17 PM   #343
6t9camaro
6t9camaro's Avatar
Ok it's finally time for an update! It's almost a year since I put any progress or pics up but a lot has changed in that time. To much time sitting and looking at awesome builds online has had me change my direction (again). I will finish off with a few pics I never got a chance to put up before I stopped and went into full teardown mode. Here are a few of the front end sheet metal going together.
Build
67 Green Gobblin
Old 03-19-2018, 06:19 PM   #344
6t9camaro
6t9camaro's Avatar
Front bumper on and checking out the front stance.
Build
67 Green Gobblin
Old 03-19-2018, 06:21 PM   #345
6t9camaro
6t9camaro's Avatar
More Stance! lol
Build
67 Green Gobblin
Old 03-19-2018, 06:27 PM   #346
6t9camaro
6t9camaro's Avatar
I Finally got the 275s mounted onto the 15x8s for the rear so I could see where it will sit. Unfortunately it was just not low enough for me with the notch I put in so thats where I stopped to rethink the build. Heres a few pics of the rear.
Build
67 Green Gobblin
Old 03-19-2018, 06:38 PM   #347
slowcpe
slowcpe's Avatar
Totally understand stand the changing of directions while reading about builds on here. The same thing cause me to buy another truck to drive over the course of the build.
Ryan
Old 03-19-2018, 06:56 PM   #348
6t9camaro
6t9camaro's Avatar
LOL Ya this is the truck I bought so I wouldn't modify my other (original) 68!
Build
67 Green Gobblin
Old 03-19-2018, 07:03 PM   #349
6t9camaro
6t9camaro's Avatar
So over the winter I gathered up some parts from a few board members here. Mirror arms, Green belts, visors, etc... put a few orders in to brothers, lmc and ordered up the Accuair E-level Air ride system. My boy was pretty excited to go through all the air ride parts!
Build
67 Green Gobblin
Old 03-19-2018, 07:22 PM   #350
6t9camaro
6t9camaro's Avatar
I pulled the (best) seat out of one of my parts trucks (72) since the seat frame in this 67 was pretty beat/bent. Plus I wanted a 71-72 seat to be able to have the Green Houndstooth style. Sent it off to the upholster with the cover and it turned out pretty good.
Build
67 Green Gobblin
