Old 05-14-2016, 01:16 PM   #26
1976gmc20
Re: '60-'66 Body On A '73-'87 Frame
I like the height on the yellow C-10 just fine
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-14-2016, 01:34 PM   #27
61K10
61K10's Avatar
Funny--It looks like a tk and most don't like it. Being old i guess i like a tk that look like a tk lol! Slammed tks are fine also, and a lot of work to build. A little lower in the front and it would look stock. Just build them guy's & gal's.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-14-2016, 09:03 PM   #28
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I don't think it's so much if it'll look okay, but more so - what's the point?
There's no advantage over just using the correct frame.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-14-2016, 11:25 PM   #29
Captainfab
60-66 Nut
Exactly!
A lot of work for no real gain. In fact IMO the trailing arms and coil springs ride nicer than the '73+ leaf springs.
Old 04-03-2017, 11:30 PM   #30
imhighlander
Bumping a bit of an old thread. I have a very rusty 1973 K20 that I'm thinking of body-swapping to a 60-66 or 67-72 body on the 73 frame. My frame is fine and I just need the front half (cab, fenders, doors, etc.). It's a flatbed and I will keep it that way. I'd appreciate any additional links or advice from the esteemed veterans here.
imhighlander is offline   Reply With Quote
Old 04-04-2017, 12:12 AM   #31
Captainfab
60-66 Nut
Do you have the means to fabricate the cab mounts on the frame? What is the law in Colorado regarding a frame and body swap. IE the frame and body having a different VIN.
Old 04-04-2017, 10:27 AM   #32
66Z71
66Z71's Avatar
Here is mine, it is a '62 body on a '73 frame. I cut the '62 cab mounts off the original frame, and re-used them on the new one. I also cut the front few inches of the frame rails off and spliced them into the '73. The front bumper wouldn't fit correctly on the new frame. The biggest headache is the frame rails kick up under the back of the cab, so you need to raise the cab, or channel the back of it to sit over the frame rails.
In the end it seemed like an easy way to get disk brakes, power steering, and newer parts.
There are some pictures in this post that show the bottom of the cab.
http://67-72chevytrucks.com/vboard/s...0&postcount=48
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 04-04-2017, 10:47 AM   #33
imhighlander
Good questions, for which I currently have no answers. I strongly suspect there is a way around those issues, but I have to figure them out. I'm not remotely concerned about the vehicle's value as an original; the amount of skin cancer eating the K20 is likely beyond repair. I do need to check out how to reconcile an earlier cab and its VIN with that of the 73 frame.
Any hints from those have gone before will be greatly appreciated. I do have the means to fabricate the cab mounts, though I don't really know what that entails until I know the respective positions of the 73 cab mounts and those of the earlier model. I do think I like the 60-66 body a little better, especially the GMCs. Do any of the particular model years hold up better from a rust perspective? Are 60-66 better/worse than 67-72?
Old 04-04-2017, 10:48 AM   #34
imhighlander
Excellent info! Thanks.
Old 04-04-2017, 12:21 PM   #35
padresag
this should help you. there is a section under Colorado that explains it
http://www.semasan.com/page.asp?cont...olbox&g=SEMAGA
ron
padresag is offline   Reply With Quote
Old 04-05-2017, 07:18 PM   #36
karlbenz
Here is my 64 on a 84 k10 chassis. pretty simple straight forward swap on a 4x4 as long as you want a 3" body lift and go with a flatbed due to frame length difference
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 04-05-2017, 07:27 PM   #37
imhighlander
That's my story anyway. Truck already has a flatbed and I'll be keeping it that way. With effectively the 3" body lift, what other issues will I run into? Shift linkage issue (4-speed manual on floor)? T-case shift lever (4wd)? Steering linkage issue? Others?
Thanks. Your rig is pretty much what I have in mind. (But with a plow on the front.)
Old 04-05-2017, 08:05 PM   #38
karlbenz
not sure bout the 4 speed. mine currently has a 700r4 with a cable. Planning on a nv4500 soon. but thats a top loader so it won't be much of a concern for me. Trans case shifter worked out fine.
I ditched the stock cooling fan for electric
My steering column was broke up inside so I ended up putting a van column in. That is something else for you to consider
1965 Chevy C60
Old 04-05-2017, 08:06 PM   #39
karlbenz
I also used the cab mounts from the 64 frame and welded them on the 84 frame
1965 Chevy C60
Old 04-05-2017, 08:17 PM   #40
karlbenz
Couple newer pics
1965 Chevy C60
Old 04-05-2017, 08:24 PM   #41
imhighlander
Couple newer pics
Looks good. Thx for all the info. I'll likely PM you when I ultimately get this underway. Lots of other things standing in line ahead of the swap. 😐
Old 09-25-2017, 12:03 AM   #42
Chevyboy02
This question is asked quite frequently, and I always try and give my opinion on the subject since I have done this once, about 20 years ago. At the time I was involved in building a truck which consisted of a '62 body onto a '74 SWB chassis, I did not think about taking pics to document the process. This truck has remained in this local area, but I just have never seemed to be able to get any better pics. That is until this last June at our local car show. I just haven't been able to find the time to post these pics until now.
As you can see, the stance of the truck is a bit high. It sits about like a stock K10. I don't remember for sure, but I believe this truck is running 31/10.50-15's. Some guys seem to like it, and others don't. While I'm not into the whole 'laying frame/rockers' thing, I do prefer a lower stance than what this type of conversion provides. There is certainly a way to do this conversion and have a lower stance, by channeling the body over the frame. It is my opinion that this is just more work than is necessary. As always I will recommend keeping your existing frame if at all possible, and just upgrading the suspension with the '73-'87 parts.
Anyway, on to the pics. As they say a picture is worth a thousand words.......
Chevyboy02 is offline   Reply With Quote
Old 09-25-2017, 12:07 AM   #43
Chevyboy02
I'm looking to do the same swap onto a k10 frame. I have taken the mounts off the 66 frame and have them ready to bolt onto the 83 k10 frame. But I was wondering if you had the measurements for the height off the frame of the radiator support mounts in front. And we're there any specific issues you ran into when doing the swap that I need to watch out for?
Old 09-25-2017, 11:39 AM   #44
66Z71
66Z71's Avatar
The rear of the cab is the first spot that will hit the new frame. I would set the cab on the frame with some 2x4's on the frame to start with, and adjust from there.
Also, save the front foot of the old frame. The bumper bolts directly to it, and you can weld it to the new frame. (Same with the rear bumper if your going to use that too)
Old 09-25-2017, 11:01 PM   #45
Captainfab
60-66 Nut
If this question is directed to me, no I do not have any measurements. This is not my truck. I helped build that truck for someone else over 25 years ago. The issues I ran into is that it is a lot of work and a PITA.
Old 09-27-2017, 12:08 AM   #46
66 Burban
66 Burban's Avatar
This was my 2 owner 69,xxx mile 63 short fleet custom on a 84 K10 frame. I sold it about 8 months ago to a guy in Canada.
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 09-27-2017, 12:38 AM   #47
rvrfoot
I dont see nothing wrong with that.
rvrfoot is offline   Reply With Quote
Old 09-27-2017, 01:05 AM   #48
padresag
"Back of the 73+ Frame sits at least 3 inches higher than the 60-66 frame. " that would make it look like the red one to me
ron
Old 09-27-2017, 09:19 AM   #49
LostMy65
LostMy65's Avatar
The point we keep leading back to is; there is no point in using the newer frames. Just use the original frame. There is nothing, absolutely nothing to gain using the newer frames.
If anything, it's bass ackwards to not use the original frame.
Just bolt up the newer crossmember, and be done with it.
Not to mention we should keep the matching VIN's.
Old 09-27-2017, 10:02 AM   #50
Clrussell
Clrussell's Avatar
What about in the case of an ls swap into a 61? I'm still researching it all
61 apache
Clrussell is offline   Reply With Quote
