Drum to disk conversion
Just joined after reading through all these old forums for weeks, I just wanted to get a fresh view on doing an all around disc brake conversion on the 70' k5 cst I just picked up. After reading and doing research I'm starting to lean towards replacing the axles instead of adding parts to the open knuckle 44. This is the first time rebuilding a truck, and all feedback would be greatly appreciated. Thanks
Re: Drum to disk conversion
IMO I would forget about putting discs in the rear. Other that bragging rights, you wont gain anything. As far as the fronts, it's been discussed a few times, but on my '70 I made my own conversion. If you're handy and can do basic machining, you should have no problems.
Your right about the rears, still have drums in the rear of my 2010 Silverado so should be fine with the 70'. The one thing that was kind of swaying me towards going with a newer front axle is the addition of the steering stabilizer. As ive read all about the steering geometry being off, especially with the larger tires. As I'm planning on doing a 4" lift with 35 x 12.5 crossover steering box was also in the thought. But if people have seen positive results with the newer axle with the stabilizer I'd have to reconsider things
#4 | |
Tags |
dana 44, disk, drum, k5 blazer, open knuckle |
