Old 04-09-2017, 06:36 AM   #1
Ta2edjr
PCM questions
Working on a 5.3 truck engine that has had a ls1 intake and injectors and shorty headers thrown on it. The last ls swap I done was just a pull out 5.3 delete vats and emissions from the pcm and that was it.
On this setup though what exactly will I need to do to get this thing running properly. Do I need a so called mail order tune? Also if so anyone recommend anyone.. TIA
Ta2edjr is offline   Reply With Quote
Old 04-09-2017, 08:54 AM   #2
mongocanfly
mongocanfly's Avatar
Re: PCM questions
You'll need the ecm reflashed for the setup you'll be running..
Old 04-09-2017, 07:43 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: PCM questions
If you just get a vats delete, it should be able to idle the thing on a stock tune. Then you can get it over to an actual tuner.
Otherwise you can do a mailorder tune, get HPT yourself and flash something off the repository, or find a tuner that will do housecalls (they exist, just rare).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-09-2017, 07:50 PM   #4
Ta2edjr
Re: PCM questions
Thanks for the info brew. I'll probably send the pcm off for vats and emissions delete and get it up and running to check for leaks and do a shakedown run...just hate to make a appointment with a tuner and show up and end up with more problems because I haven't even heard it run yet and waste mine and the tuners time chasing small problems that could have already Ben taken care of.
Old 04-10-2017, 12:21 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: PCM questions
I would also ask them to update the tune with the LS1 injector data.
Hart_Rod is offline   Reply With Quote
