Old 04-09-2017, 11:07 PM   #1151
joedoh
joedoh's Avatar
Re: My 50 roadster pickup build
jeeze your gorgeous work makes me feel like a caveman banging rocks together sometimes.
Old 04-09-2017, 11:36 PM   #1152
oldman3
oldman3's Avatar
Originally Posted by Scott2 View Post
Very nice work!
Thanks Scott
I know your not that bad, appreicate the thoughts...Jim
oldman3 is offline   Reply With Quote
Old 04-10-2017, 07:43 PM   #1153
oldman3
oldman3's Avatar
Today's update. I had stuff I had to do this morning early, so Mark picked back up where we left off Saturday.
Pic 1 The right brace not lining up with other holes.
Pic 2 Mark cut off the top of brace and rewelded in new location.
Pic 3 Much better that before. Just a note, when top panel is attached it pulls the grill in line with the new hole.
Pic 4 & 5 The bottom of same brace needed to be moved, so Mark cut and welded, so it lines up with bottom panel.
Old 04-10-2017, 07:50 PM   #1154
oldman3
oldman3's Avatar
Here you can see the grill, fenders, hood are looking a lot better that when we started.
Mark and I also took the time to place each chrome bar back on main frame, checked and the tips of each bar was going to hit the fenders. Mark took his aluminum hammer and worked the ends to give us the clearance we needed.
Old 04-10-2017, 07:58 PM   #1155
oldman3
oldman3's Avatar
While truck was still in the shop, I had Mark weld in new tabs for the headlight bucket. The newer Hagen set-up has the tabs in different locations than the orginal I did 13 or 14 yrs ago. I cut out the old tabs, Mark made new ones and welded them in place. I'm out of the shop for a few days, customers first, so I'll update as necessary...Jim
Old 04-14-2017, 11:26 PM   #1156
oldman3
oldman3's Avatar
Nothing major, just put the grill back together, and took it to the basement, till needed...Jim
Old 04-15-2017, 03:06 AM   #1157
joedoh
joedoh's Avatar
boy howdy that blue tape on the grille. I thought you had switched to riviera blue for a second. thats my very favorite color, so dont blame me for getting excited.
Old 04-15-2017, 09:34 AM   #1158
oldman3
oldman3's Avatar
...Jim
Old 05-02-2017, 09:32 PM   #1159
oldman3
oldman3's Avatar
Well you folks ready for my sob story. It's been at least two weeks with nothing to show. But was finally able to get a little work done. Lots of pics with "how and why", might get boring.
Pic 1 This is how the Hagen lamp base aligns with tabs, drill holes and install screws (weather bad sat 4/29 when to house)
Pic 2 Back in shop, installed lamp assembly and installed retainer ring.
Pic 3 Drivers side same as pass.
Old 05-02-2017, 09:46 PM   #1160
oldman3
oldman3's Avatar
A few days later after finding some problems, Mark and I talked about not being able to adjust highlights without removing retainer ring, so it was decided to modify the retainer ring so the large holes align with the screw heads with lamp base, and just drill new holes for retainer ring to screw into lamp base. Which is what I did today. (sorry not pics)
Pic 1 I also found out that the chrome ring for light would not sit level on the lamp, because of two nubs on the glass (made during manuf). These are new LED stuff I bought some time back. The lamp assembly is by HELLA made in Germany and DOT approved, has glass lens and metal housing, nice stuff.
Pic 2 So after about 30 minutes of grinding I cut down the nubs to clear.
Old 05-02-2017, 10:00 PM   #1161
oldman3
oldman3's Avatar
Pic 1 This is the lamp assembly with metal piece for the notch in base.
Pic 2 LED light
Pic 3 New LED light assembly (plug and play)
Pic 4 All assembled
Pic 5 Light on low beam, way better that the old H4 bulbs
Old 05-02-2017, 10:03 PM   #1162
Hampshire
Hampshire's Avatar
Looks like you're closing in - and, it's going to be even better then before.
Hampshire is offline   Reply With Quote
Old 05-02-2017, 10:03 PM   #1163
youngrodder
youngrodder's Avatar
Nice Jim....curious is Mark going to modify the lamp base by adding steel like he has done before for better adjusting (see pics for reference)? I just bought some 11g steel today to make a couple new base rings and follow Mark's lead. Your repair is looking good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-02-2017, 10:05 PM   #1164
youngrodder
Nice to know about the LED upgrade. I need to pull the trigger on those myself. Did you get them off of EBay?
Marc
Old 05-02-2017, 10:08 PM   #1165
oldman3
oldman3's Avatar
After supper and watching the news, I came back to shop and hooked up my new LED running and turn signals. They are much brighter that the pics show.
Pic 1 Running light
Pic 2 Turn signal
Pic 3 Off
Old 05-02-2017, 10:09 PM   #1166
oldman3
oldman3's Avatar
Thank you...Jim
Old 05-02-2017, 10:12 PM   #1167
Indian113
Indian113's Avatar
Oh Yeah! That was worth the headache for you, at least I think I would be Happy with it.
Indian113 is offline   Reply With Quote
Old 05-02-2017, 10:14 PM   #1168
oldman3
oldman3's Avatar
Marc
As of right now, NO, but that could change.
Marc
No I got them through Watson's street works. They are pretty steep on price but nice. The only reason I went this way is I didn't already have lamp assy's to just change to the LED lights. (one was broken in the accident) I already had these before I seen lower50's post, otherwise I would have done the same. My turn signal is also from Watson's. Mark and I have used their stuff for years with no problems, and he will work with you to fix someone else's stuff, nice guy...Jim
Old 05-02-2017, 10:15 PM   #1169
oldman3
oldman3's Avatar
Thanks Ray, yes I'm real happy with both the LED changes...Jim
Old 05-02-2017, 10:36 PM   #1170
oldman3
oldman3's Avatar
Well, I couldn't help myself, wanted to see how the headlight worked. These isn't a good comparison because I only have one headlight working on the 50 and the new Buick has both, but I'm happy with what I see. Once both are in and adjusted they will be better..Jim
Pic 1 Buick lights
Pic 2 50 lights
Old 05-02-2017, 10:52 PM   #1171
oldman3
oldman3's Avatar
Since I've been so slow in getting anything done. Mark and I talked about the NSRA mid-american nats, last of this month. I've been to every one since I finished my truck, and I not going to miss this one (13 yrs). So, I will remove the drivers fender and inner, spray with epoxy primer, do body work, spray with sandable primer, reinstall everything. Give it a good shake down run and drive it to the event. Then after that I will tear it back apart, clean up everything, and start getting it ready for paint. Soooo hopefully I will have some more to post soon...Jim
Old 05-03-2017, 12:05 AM   #1172
lower50's
lower50's's Avatar
Looking good Jim!! I like the marker lights. One thing it looks like the cut off on the '50 is better than the Buick.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-03-2017, 06:36 AM   #1173
Indian113
Indian113's Avatar
Glad to hear you have a Goal! I was wondering if you were going to make the Nat's. Don't forget your Camera and take Lots of Pictures-PLEASE!
Old 05-03-2017, 10:18 AM   #1174
oldman3
oldman3's Avatar
Thanks lower, I'm very pleased so far...Jim
Old 05-03-2017, 10:19 AM   #1175
oldman3
oldman3's Avatar
Thanks Ray, having a goal, and getting it done, that's the hard part. I will take pics...Jim
