04-10-2017, 12:57 AM | #426 |
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Hi. Wondering what colour the back side of the parking light bezels in a 1961 GMC would be? I think the inside was some sort of cadmium plating? Is the outside the same? Or black? Or? Thanks.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
04-10-2017, 07:43 AM | #427 |
There are a light Galvanized color. I blasted mine and repainted with hi-temp aluminum.
http://s1299.photobucket.com/user/jb...23904108567829 |
06-15-2017, 06:54 PM | #428 |
Hello All,
Does anyone have any formulation information for the acrylic primers for GM cars and trucks during the years 1965-1967? I have an old code or two that I'm interested in learning more about GM-3, and GM-44. I believe the first code is for an acrylic primer, and the second is for an actual paint. Any and all information would be extremely helpful. Todd |
06-30-2017, 11:56 PM | #429 |
Rollin' Old Skool
Couple questions:
For the factory 327 engine air cleaner/breather, what sheen of black would be correct? Semi-gloss, gloss, satin? Also, what kind of paint are you guys using for the exhaust manifolds? I assume cast iron gray would be correct?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-11-2017, 10:56 PM | #430 |
1966 factory exhaust system question.
I have a stock 1966 short bed with an inline 6 250 and 3 speed manual trans. It came with the exhaust manifold but no exhaust system. There is also no flange, gasket, hangers or brackets. I have found and purchased a new system (front pipe, muffler and tail pipe). It however didn't include the rest of the parts or any installation instructions. Does anybody have any diagrams, photographs, etc. that would help me figure out what parts I still need and how the whole system should be installed? Thanks. Posted via Mobile Device |
07-16-2017, 02:24 PM | #431 |
Fun thing we found on the 62 burb, Wiring number.
10-03-2017, 12:17 AM | #432 |
Active Member
On the 1960 C10 Long bed stepside I am restoring, the interior has a dark gray dash with a silver gray trim, which is also the rest of the interior of the cab. Does anyone know if there is a paint code associated with these colors?
Submariner616 1965 Chevrolet K20 350 4 speed manual |
10-18-2017, 10:49 PM | #433 | |
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
10-19-2017, 12:28 PM | #434 |
Cool! That label is rarely intact. It's a paper sticker meant for assembly ID, and not very resistant to engine washing or other abuse. Two of my trucks had that label in fine shape, but I failed to wrap one of them in clear tape before an engine wash, and it took a toll on the poor label. Doh!
10-30-2017, 12:01 PM | #435 |
A thread from another forum I am working on...this may or may not apply to our trucks but curiosity has gotten me to thinking about the applied torque values, for all those that have restored or original driveshafts one piece but we`ll extend it to two piece driveshafts if you guys would chime in on those that have a drive shaft that has the yokes offset by 20% here is the thread it applies to only the small block camaros, all the big blocks were in line... Current thread..
I have seen two examples where the yokes on each end of the center tube section of driveshafts from Norwood built 1969 Camaros were not "in line" with each other, but offset - one with respect to the other - by approximately 20 degrees. One of these driveshafts was originally in my 69 RS coupe which I have owned since Nov 1991 (VIN# 124379N581767, 01C build date). The other driveshaft was from a 69 Camaro base coupe, 327, built around the 3rd week of November 68 (VIN# 124379N551248, engine code V1122FJ). Both cars are base V8's, my RS has a Powerglide, the other car had a 3 speed manual. The other car was being parted out back in March 1994, so I collected several items, including the 327 motor and the driveshaft - which I still have. All other driveshafts that I can remember (other than these two) have the yokes "in line" (0 degree offset) from end to end. The reason(s) that the "as built" offset doesn't seem right to me, in that fundamentally, a driveshaft is designed to cancel out the inherent variations in rotational (angular) velocity from one end of the driveshaft to the opposite end and change those variations in angular velocity to essentially constant velocity. How well the driveshaft does its job is a funciton of several items. One key element is to ensure that the included angle between the transmission and the center tube is the same as the included angle between the center tube and the differential. If these angles are not the same (+/- tolerance), the resulting non uniform angular velocity between the driver and driven ends of the driveshaft can result in potentially very high inertial forces, resulting in vibration, and eventual damage. In addition to maintaining the proper angular relationships, the other key element is to ensure that the yokes on each end of the center tube section are in line (0 degree offset) with respect to each other so that the center tube can articulate by the same angular amount, but in opposite directions, from one end to the other. So here is the crux of my question. The two driveshafts that I referenced above clearly do not have the yokes in line with each other with 0 degree offset. They are offset by approximately 20 degrees. Consequently, it seems to me that it would be impossible to maintain the proper angular relationship between the transmission and differential during operation because the center tube cannot articulate properly. Did Chevrolet actually design the driveshafts this way for 1st Gen Camaros? If so, why - no other car that I know of ever had offset driveshaft yokes. If Chevrolet did design the driveshaft this way, what was their logic? What was different in 1st Gen Camaros that would require the offset?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
11-12-2017, 04:26 AM | #436 |
Seat tag found 2 of them on the front seat springs.
Anyone know the code for the last set of nr´s? 377 3039? Last edited by sirJim; 11-12-2017 at 04:30 AM. Reason: wright more. |
11-23-2017, 11:11 AM | #437 |
can we talk about the correct rim color for 1965 c10. i see them white i see them black and i see them body color.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
11-23-2017, 11:58 AM | #438 |
Hi Jim , for Chevrolet there never was a white rim on a 10-20 or 30 series, white rims are GMC only. On a solid white or off white truck the rim was black whether it was a custom or not. Also should mention here that white custom trim trucks only had white between the custom side door and bed trim , you see lots of black and red painted inserts on them but this is NOT factory. Two tone trucks got the main body color painted rims. While one color or solid color trucks received black rims on Chevys.
GMC was completely different. For 1960-1961 There were three colors for the rims ,Crystal Green, Strata Blue and Olympic white , this all had to do with the main body color as to which wheel color you got.For 1962-1966 Im 90% sure GMC rims were white but for some reason I have seen a couple with black rims that I cannot verify. Still need a 1962 and 1966 GMC Data book to confirm some of the GMC facts.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
11-23-2017, 12:17 PM | #439 |
Very informative really appreciate the info
11-23-2017, 12:49 PM | #440 |
Active Member
Hello, I am doing a stock restoration of a '60 C10 and I don't know what to do with this steering column joint. There is a lot of old grease in there, there is no grease fitting, the boot is caved in, please see pictures. Any ideas?
11-24-2017, 11:58 PM | #441 | |
Rollin' Old Skool
12-01-2017, 01:34 PM | #442 |
OEM UNUSED/UNMOUNTED tailgate for GMC. A friend send me these pictures of a NEVER used or Mounted tail gate. Note the GRAY chain covers, this is how the gate came from the factory. The owner removed the gate to mount a camper and put the gate on the wall of the garage.
I've seen clear chain covers and Black chain covers, but never saw grey, one more thing to put on the list, I wonder IF Chevy did the same?.
12-01-2017, 01:56 PM | #443 |
Wow, super nice! Is it for sale?
Yes, orig chain covers are ribbed gray for Chevy. |
12-01-2017, 02:09 PM | #444 | ||
Yes , thats correct Quote:
12-01-2017, 02:25 PM | #445 | |||
Rollin' Old Skool
Great info on the chain covers! Did not know that. Oh, & thanks for clarification on the sheen for black wheels.
12-01-2017, 04:25 PM | #446 |
[QUOTE=oem4me;8094518]Wow, super nice! Is it for sale?
Yes, Pm and I'll pass along the name/number
12-10-2017, 08:18 PM | #447 |
Do the serial numbers for each year start with 100001 like the 55-57 Chevys? My '60 Apache is 100237 which would be pretty early then. I noticed the bellhousing had a F239 date code which I believe would be June of '59?
12-10-2017, 08:38 PM | #448 |
Active Member
I'm going to pull the cab off my 60 C10 to have it dipped and stripped. Is the undercoating on the underside stock from the factory or was it added later? Thanks!
12-14-2017, 12:02 AM | #449 |
Active Member
While restoring my 60 C10 as original as possible, I will paint it white because that is the paint code on the plate. It looks like somebody (dealership?) painted it Brigade Blue and did a thorough job.
My question is, on the white ones from the factory, was the Chevrolet lettering on the tailgate painted black or left white? Thanks!
12-14-2017, 12:19 AM | #450 | |
