Old 04-11-2017, 01:00 AM   #1
elane352
Navigation System Install Suggestions
Hello,
The prior owner of my 64 C-10 has cut the dash to install an Alpine DIN radio. An oversized aluminum sheet has been used to cover any gaps between the radio and the cut dash. I cannot stand the aluminum. It looks tacky and I want to get rid of it.
I am debating replacing the Alpine unit with a Navigation system (i.e., cut the opening even more); or finding a nice black cover that is not oversized that looks neat.
I do not have a problem losing the ash tray since I do not smoke. I am assuming it would have to go since I would think at least a 4 inch high opening would be needed.
If I go the Navigation system route, what is the best tool to use to make the cuts? Would you have enough control using a cutting wheel to make neat cuts?
Eddie
elane352 is offline   Reply With Quote
Old 04-11-2017, 09:16 AM   #2
siggyfreud
siggyfreud's Avatar
Re: Navigation System Install Suggestions
Air tool with a small cutoff disc, or Dremel with a disc would give you the best control. Or a plasma cutter if you have surgeon hands
siggyfreud is offline   Reply With Quote
Old 04-11-2017, 12:36 PM   #3
Clyde65
Clyde65's Avatar
I also would drill the corners, another option is an air saw...you got to control them tho
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-11-2017, 12:49 PM   #4
siggyfreud
siggyfreud's Avatar
Yeah that's a good idea. If you have a hard time controlling the tool you might drill more often too, and then just connect the dots. Or rather than cutting the lines fully, just cut the width of the tool in spots, and slowly overlap, kind of like tac welding something you don't want to warp.
Old 04-11-2017, 05:00 PM   #5
elane352
Okay Gents; thank you much.
I do have a Dremel tool. So it sounds like it would be a good time to put it to use.
Eddie
