Junior Member
![]() Join Date: Mar 2011
ls fuel pumps problem
looking for some help with my ls1 swap. My saddle mount pumps seem to last 30 min of run time , msd pump corvette style filter regulator, I have 13.7 volts to the pump , pump is at same level of outlet on tank, psi reflash and wiring pump relay at fuse panel truck is not blowing 20 amp fuse or any relay damage any idea's what I could be missing
![]() ![]() Join Date: May 2015
Re: ls fuel pumps problem
Are you saying the pump quits and dies..and never works again..check your ground..I used a walbro 255 on mine..
Junior Member
Thanks mongocanfly for the tip on the ground I cut the pump apart and found some aluminum chips in it ? I'm going to try a better pre filter
Yep..aluminum in the pumps not good either..do you have a aluminum tank?
Which brand filter/regulator are you using ?
Junior Member
Yes it is a aluminum fuel tank This had been a on going build [many years] of sitting due to other obligations I did have a new vent installed years ago and overlooked a good cleaning when the time came for start up, and only had a small filter on it. Costly mistake
I'm running a big Aeromotive in-tank pump, but I run a 100 micro pre-filter and a 10-micro post-filter. Protects the pump from large chunks like that.
For a more conventional style pump, you'd think the "sock" would catch that kind of stuff...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
