Old 04-11-2017, 10:56 AM   #1
bbluma
How is radiator suppose to be held in place?
Hey y'all. So I'm trying to figure out what the proper way a radiator is to be bolted, or held in place. Truck I bought, former owner literally just took an extension cord and wrapped it around the support. I know it has aftermarket radiator support, and I've read that some don't have all the holes needed. So any help is appreciated! Thanks
bbluma is offline   Reply With Quote
Old 04-11-2017, 11:12 AM   #2
TopFuel1966
TopFuel1966's Avatar
Re: How is radiator suppose to be held in place?
It depends on what kind of radiator you have. The factory radiator mounts in two rubber lined stirrups on a crossmember on the bottom and a bracket that bolts to the grille support on top while some aftermarket units have flanges which allows mounting directly to the back side of the grille support.
TopFuel1966 is offline   Reply With Quote
Old 04-11-2017, 11:21 AM   #3
62stepside longbox
62stepside longbox's Avatar
Also depends what year your truck is, 60-62 just bolts straight to the rad support, it doesn't rest on rubber pieces like 63-66 does.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-11-2017, 11:26 AM   #4
bbluma
My fault, it's a 66' with a champion radiator. Not sure what model or anything of champion. Does the 66 have the piece that goes over the top and connect to hood mount ?
Old 04-11-2017, 11:55 AM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
You can see in this picture in the bottom right corner what it looks like. Now just have to find one or get something bent up that will work.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-11-2017, 12:01 PM   #6
bbluma
You know of anywhere to get one? Or what the proper name of the part is?
Old 04-11-2017, 12:55 PM   #7
Clyde65
Clyde65's Avatar
One thing, since Champions are more square that the original, it's advisable to actually use a thinner rubber under the steel mount than you would on an original mount. Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-11-2017, 11:40 PM   #8
Chevy Fleetside
try e bay. I will see if I have an extra when I go to my storage/shop space. Saw one on E Bay but he used the word "Rare" and is asking $159. I don't think you want to pay that much for one. Plus he said it was a wider radiator.
