Old 04-12-2017, 08:07 AM   #1
albertan82
Advice on the gear ratio for 350 vortec with TH350 -
Hi ,
I have a 1964 C10 Stepside - short wheelbase, with 350 5.7 vortec and TH350. Tires are 225/75R15 (28.5").
Current differential is from a 1973 Chevrolet Caprice (350 engine) added to the truck by the previous owner, but I do not know the current gear ratio. It is the 10 bolt, 8.5", 28 spline differential.
When I drive on the highway at 60mph, tach is showing around 4000rpm (
What gear ratio would be the best for this engine-trans-tire combo?
Thank you all in advance
Istanbul, Turkey
albertan82 is offline   Reply With Quote
Old 04-12-2017, 08:40 AM   #2
James the III
Re: Advice on the gear ratio for 350 vortec with TH350 -
Originally Posted by albertan82 View Post
Hi ,
Istanbul, Turkey
I'd get another tach and see if that one is reading correctly..
at 4000 rpm with a 28" tall tire, and a 1 to 1 3rd gear (th350) at 60 mph
is a rear gear of 5.56 not likely..
you can get a ballpark,, by putting the rear axle of the car on jack stands..
mark the driveshaft. and mark the tire put the car in neutral , car not running..
and turn the driveshaft until the tire makes one full turn/rotation.
counting the # of times the drive shaft turned..
it turns 3 and 3/4 times.. most likely have 3.73 gears
3 and 1/5th 3.23
just over 3 3.07
3 and just under a 1/2 3.42
little over 4 times. 4.11
etc.
James the III is offline   Reply With Quote
Old 04-12-2017, 08:44 AM   #3
cdub2010
http://www.4lo.com/calc/gearratio.php
plug in what numbers you want
cdub2010 is offline   Reply With Quote
Old 04-12-2017, 08:46 AM   #4
James the III
http://www.wallaceracing.com/calc-rgr.php
Calculate Rear Gear Ratio
for given MPH, RPM and Trans Gear Ratio
When I plug in the numbers but in the trans gear ratio I put the th350 2nd gear ratio of 1.52
I get a more normal 3.66 and with the speedo being off, your tach being a tad off..
and me using 28" tire not 28.5"
it get close to a g.m. 3.42 rear gear..
So.. let me ask, are you sure it's going into high gear.. and not going down the highway in 2nd
Old 04-12-2017, 11:25 AM   #5
kwmech
Go with a 3.08
Old 04-12-2017, 05:50 PM   #6
Dead Parrot
Since it is a mix of parts, it is very likely that the speedometer gear unit in the transmission isn't correct for your setup and giving a wrong speed reading. Get a chase vehicle or gps unit and confirm your speed.
Dead Parrot is offline   Reply With Quote
Old 04-12-2017, 05:58 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Agree with a 3.08. That's what I have on my 69 and it was a decent street ratio and also had no trouble pulling an 18' trailer with a full size tractor and shredder (no tall hills).
As for the ratio on your truck, in some cases there's a number stamped on top of the passenger side axle tube. Years of grime may have covered it so use a wire brush to clean it if it's crudded up. I found removing the passenger side tire gave me a better view of the number on mine.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-12-2017, 06:30 PM   #8
Alex V.
Alex V.'s Avatar
Stock engine? 3.08's if you don't want it to pull very much comfortably, around a 3.36 or maybe a 3.42 (popular in the 90's 1/2 ton 2WD trucks) if you want it to tow a little better.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 04-13-2017, 01:07 PM   #9
Tom
driving is in my blood
Tom's Avatar
I wouldn't do anything steeper then 3.07's, you don't have overdrive. You'll still be at 3k running 80mph with 3.07's.
differential, drivetrain, gear ratio, th350, vortec
