Old 04-12-2017, 04:53 PM   #1
terry b
terry b's Avatar
Oil pressure line
Is the OEM oil line from the block to the oil pressure gage in the dash steel? 1972 402.
terry b is offline   Reply With Quote
Old 04-12-2017, 05:12 PM   #2
BILT4ME
Re: Oil pressure line
Usually 1/8" OD soft copper.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 04-12-2017, 05:13 PM   #3
hayhauler71
hayhauler71's Avatar
Mine was 1/8 inch steel on my 350. Replaced with copper.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-12-2017, 05:26 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My OEM was steel that had a rubber sleeve over it. It rusted out and ruptured, so I replaced it with copper line.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-12-2017, 05:26 PM   #5
El Dorado Jim
steel from the factory....
El Dorado Jim is offline   Reply With Quote
Old 04-12-2017, 06:15 PM   #6
davepl
davepl's Avatar
For what it's worth, I think copper is probably safe, but it does work harden. If you have it in a an area where it'll get repeatedly bent or flexed, it'll fail eventually. Imagine if you had a oil pressure gauge on your hood, for example, and every time you opened the hood it'd flex it.
Mild steel is much more resistant to work hardening than copper, which is maybe why the factory went that way.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
