04-15-2017, 11:30 PM | #1 |
Need HELP IDing wire under the hood
Pretty much done with my 87 V10 but have 1 wire under the hood that I have no idea what it goes to. It is behind the drivers side headlights and comes from the headlight harness. It is tan in color, has a small bracket attached to it, & the end is cut off.
If anyone can shed some light as to where or what this connects I would really appreciate it. I checked wiring diagrams but nothing jumps out to me that might explain it. Any info is greatly appreciated. Thanks Scott
1963 C10 swb fleetside 1966 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
04-16-2017, 01:16 AM | #2 |
Re: Need HELP IDing wire under the hood
Check to see if it fell of your proportioning valve towards the front of the vehicle in the frame. Kinda looks like that kinda plug
04-16-2017, 01:18 AM | #3 |
that what it is for the brake light in the dash
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
04-16-2017, 09:33 AM | #4 |
thanks guys, had an idea thats what it was for but did not know where to look.
Will check it out.
