Old 04-16-2017, 01:55 AM   #26
68bowtie
68bowtie's Avatar
Re: 1971 c20 big block camper part out
Originally Posted by 1972BackInBlackC10 View Post
interested in the dash vents (defrost) and the arm rests, what kind of shape, price, pics?
also hows the dash pad and the ash tray?
no arm rests. one dash vent is trashed. the other is pretty good, but some flaking in the paint (see pictures). 4 bucks plus shipping. dash pad is junk. ash tray is in great shape, the original paint is chipped a bit. 10 bucks plus shipping. can ship both for 22 bucks.
Originally Posted by MikeCofield View Post
I'll take the carb . Dist , power steering brackets ,alternator brackets
I'll take crank pulley water pump pulley
carb, dist, crank & wp pulleys, alt & ps brackets all in one box is going to be about 70 bucks (nearly 30 lbs and a long haul). i'll take 20 off and do everything shipped for 260 if that works.
Originally Posted by jhuerta81 View Post
Automatic column? Tilt? Condition?
standard auto column. it's a bit rougher than i originally thought. price dropped to 60 plus shipping.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 04-16-2017, 02:11 AM   #27
68bowtie
68bowtie's Avatar
Originally Posted by BlueBoy72 View Post
Are the lower retaining clips for the fan shroud available?I'm interested if they are the same as a 1972 with bbc and a/c.
yes! they are well preserved under a coat of grease. how does 8 bucks shipped sound?
Originally Posted by Jens Jimmy View Post
I'll take the motor mounts, pending shipping quote ton 72764
Should have read closer, I saw the price for the heat shield, I will take it also.
these should fit together in a large flat rate box for $18.85.
Originally Posted by mo View Post
I'll take the radiator brackets shipped to 93013
$7.15 for shipping.
Originally Posted by Gary 70 Jimmy View Post
I will take the spot light and how nice is the review mirror.
the mirror would clean up pretty nice on the outside, but the inside of the glass has spots, so i'm not sure if that's fixable. either way it's a medium flat rate box for $13.60 (just spotlight or both pieces).
Old 04-16-2017, 02:26 AM   #28
Cheyenne1970
I'm interested in the fan shroud could you post pictures of it because I'll take it if it doesn't have any cracks.
Cheyenne1970 is offline   Reply With Quote
Old 04-16-2017, 02:34 AM   #29
68bowtie
68bowtie's Avatar
Originally Posted by REEDS 72 View Post
I will take the fuel line from carb to fuel pump LMN thanks
how about $14 shipped? threads are nice.
Originally Posted by 6t9camaro View Post
Interested in the pedal, th400 kick down and throttle cable/bracket. Is the kick down switch on the carb or pedal?
pedal mounted switch. includes the wiring too. parts should fit in a medium flat rate box for $13.60.
Originally Posted by Rods View Post
I will take the Jack,handle and mounting hardware.....
$24.04 ground shipping.
Originally Posted by DeadheadNM View Post
Interested in the AC firewall box and o5her AC pieces - how is the metal backing for the AC box? Solid and no rust? Thanks, pete
there are a few small areas of surface rust, should clean up really nicely.
Interested in the vacuum port and tube that goes to booster
do you have a picture of what you're looking for? is it a hard line?
Old 04-16-2017, 02:41 AM   #30
68bowtie
68bowtie's Avatar
Originally Posted by Cheyenne1970 View Post
I'll take the crank pulley and power steering pulley
I'll also take the air cleaner pending pictures. Thanks
you are in line on the crank pulleys. i assume you mean the 3-groove crank set, and not the pulley on the ps pump?
air cleaner pics. solid and straight. it's missing the nose thingy. i'm thinking 20 bucks...
Old 04-16-2017, 02:48 AM   #31
1972BackInBlackC10
1972BackInBlackC10's Avatar
thanks ill pass on the vent and ash tray, I was looking for a good set of vents and my ash tray is in good shape just the inside has some surface rust
1972BackInBlackC10 is offline   Reply With Quote
Old 04-16-2017, 02:54 AM   #32
68bowtie
68bowtie's Avatar
i looked it over today, it has no cracks. great shape. i'll post pictures tomorrow.
Old 04-16-2017, 08:34 AM   #33
randy500
Interested in the outside A/C box if deadhead passes. Maybe the inside one too. Price on it shipped?
Price shipped on the condenser to 98409
randy500 is offline   Reply With Quote
Old 04-16-2017, 09:50 AM   #34
MikeCofield
Any pics of vacuum port and tube that connects to booster
MikeCofield is offline   Reply With Quote
Old 04-16-2017, 09:52 AM   #35
MikeCofield
Yes it's a hard line the vacuum port screws in the intake behind carb and hard line screws onto it
Old 04-16-2017, 09:54 AM   #36
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Surface rust is no problem - I'll take the AC components pending ship cost but can you please double check all the metal on the back of the box including the flapper and the parts around the blower motor under and around the seal - pic looks to show some rust holes near the blower motor seal? I've been burned by hidden pitting rust in the past and am chasing a solid piece. Is the fiberglass in good shape with no holes? The attachment bolts and screws would be a big help.
Thank you. Shipping to 87107.
Old 04-16-2017, 10:38 AM   #37
jhuerta81
How much for the front bumper L shape brackets shipped?
jhuerta81 is offline   Reply With Quote
Old 04-16-2017, 10:53 AM   #38
BlueBoy72
Active Member
I will take the shroud retaining clips.Paypal and shipping address is on the way.Thanks.
BlueBoy72 is offline   Reply With Quote
Old 04-16-2017, 11:28 AM   #39
mo
I'm in on the 4 core radiator brackets
Please send me a play pal request or pm me with payment method preferred
Thanks mo
72 Cheyenne super swb 4x4
68 CST swb anniversary gold
67 custom swb 4x4
mo is offline   Reply With Quote
Old 04-16-2017, 11:32 AM   #40
mo
Never mind.
I just read your post and PayPal info is at the top.
Money coming your way.
67 custom swb 4x4
Old 04-16-2017, 11:35 AM   #41
mo
Money sent
67 custom swb 4x4
Old 04-16-2017, 11:37 AM   #42
old51sedan
old51sedan's Avatar
I'm interested in the front stabilizer bar & clamps. Also does the horn/horns work, if so interested.
old51sedan is offline   Reply With Quote
Old 04-16-2017, 11:51 AM   #43
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
I will pass on the spot light and mirror thanks Gary
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 04-16-2017, 11:52 AM   #44
crossjo
I'll take the jack if it hasn't already been spoken for.
crossjo is offline   Reply With Quote
Old 04-16-2017, 12:09 PM   #45
MikeCofield
Port pic
Old 04-16-2017, 04:18 PM   #46
Tchevy68
I'll take the a.c. vents. $20 for all 3? Shipped to 42303
Tchevy68 is offline   Reply With Quote
Old 04-16-2017, 06:23 PM   #47
56 chevy
Was looking for a lug wrench for 7/8 lug nut if you have price shipped to 23325
56 chevy is offline   Reply With Quote
Old 04-16-2017, 07:50 PM   #48
Jens Jimmy
Hey 68, waiting on response on motor mounts and BB, exhaust heat shield. If the mounts are still under the motor, I understand. No hurry. If you can get me a total, I will get you paid.
Jens Jimmy is offline   Reply With Quote
Old 04-16-2017, 08:00 PM   #49
68bowtie
68bowtie's Avatar
i think this is it. if so i'll throw it in with the other parts since you're buying so many.
Old 04-16-2017, 08:01 PM   #50
68bowtie
68bowtie's Avatar
no cracks. tabs are good. nice original piece.
