Old 04-16-2017, 06:04 PM   #1
jdime20
Walbro 450 on stock blazer sending unit
My plan is to simply cut the bottom sock of the factory pick up tube and pit the walbro on it with the short hike and clamps....seems very simple, but haven't seen anyone do it yet. Is there something I'm missing?
jdime20 is offline   Reply With Quote
Old 04-16-2017, 06:54 PM   #2
72again4x4
72again4x4's Avatar
Re: Walbro 450 on stock blazer sending unit
I did it on mine and works like a charm. Double check your measurement on tank depth and go for it. I would send pics but mine is installed and I didn't take any pictures. When you mount the pump, also double check the hinge area on the float wire. My pump was rubbing and prevented full range of motion.
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 04-16-2017, 07:15 PM   #3
jdime20
Did you set it up so that the walbro sock is just barely off the bottom of the tank?
Old 04-16-2017, 08:20 PM   #4
72again4x4
72again4x4's Avatar
Yes I did. I have an 87 blazer tank and sending unit. It measured 10 3/4 inches to the bottom and with the pump mounted vertically it sits just below the sending unit float attachment. Pump is approximately 1/4 off the bottom of the tank.
Old 04-16-2017, 09:59 PM   #5
jdime20
Awesome, I was sure this would work and am surprised I haven't seen more people doing it. A lot simpler than most stuff I've seen
Old 04-17-2017, 08:32 AM   #6
solidaxel
solidaxel's Avatar
Where are you placing your return line
How are you getting your 12VDC connection outside of the tank?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-17-2017, 08:58 AM   #7
72MARIO
72MARIO's Avatar
What year tank are you using ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-17-2017, 09:45 AM   #8
72again4x4
72again4x4's Avatar
HI solidaxel,
Was that question for me or the OP. Not trying to take over the thread.
Old 04-17-2017, 11:57 AM   #9
solidaxel
solidaxel's Avatar
jdime20, maybe he is going to use a 87 Blazer float with the return line
LS 3 4L70E
Old 05-11-2017, 08:24 PM   #10
jdime20
I'm using the blazer tank from the 67-72 models. I'll get some pics tomorrow
Old 03-11-2020, 07:47 AM   #11
Ford Assassin
Ford Assassin's Avatar
3 year bump for updates...
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
