Old 04-17-2017, 09:47 AM   #476
mcbassin
Still Learning
mcbassin's Avatar
Re: 67 GMC super custom build
Very nice work on everything! Good choice upgrading to disk brake BTW.
Old 04-19-2017, 11:52 AM   #477
67 Burb
67 Burb's Avatar
When you installed the metric speedo, did you get the numbers on the lens custom done, or are they available somewhere?
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 04-19-2017, 11:55 AM   #478
Phill0406
Phill0406's Avatar
Love that you're keeping all the original touches to it. Great work.
Phill
68 Anniversary build - LS swap & Porterbuilt
Instagram @fourdoorphill
Phill0406 is offline   Reply With Quote
Old 04-19-2017, 12:51 PM   #479
chewychevy67
The speedo is all original gm parts. I got them from a member in sweeden. I just added the speed warning to it. I had the vacuum lettering added cause it wasn't stock in this cluster
chewychevy67 is offline   Reply With Quote
Old 04-22-2017, 11:31 AM   #480
chewychevy67
I picked up the steering wheel yesterday. Looks very nice. Great detail work.
Old 04-22-2017, 11:40 AM   #481
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Very nice Rod - thanks for posting
Old 04-22-2017, 04:46 PM   #482
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Looks brand new..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-23-2017, 02:46 PM   #483
chewychevy67
Got this rear sway bar I am going to use on the truck.
Old 04-23-2017, 04:59 PM   #484
kehstr
kehstr's Avatar
what is the sway bar off of?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-23-2017, 05:04 PM   #485
chewychevy67
I bought it off a member that had it on a 68 C20 with leaf springs but I am unsure what it originally came off of. Here are all the pictures I have of it. I recently found out it is from an square body dual rear tire 1 ton truck.
Old 04-24-2017, 09:51 AM   #486
chewychevy67
Finished up.
Old 05-13-2017, 03:13 PM   #487
duallyjams
duallyjams's Avatar
here are a few more with the gauges in.. I think it looks period acceptable.
so where is the 67 impala steering wheel now that you have the custom one ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-14-2017, 01:28 AM   #488
chewychevy67
I sold it on ebay. I tried to sell it on here for 3.5 months and nobody wanted it. After I sold it on ebay quite a few members PMed me about it. Funny how that happens sometimes
Old 05-23-2017, 08:01 PM   #489
chewychevy67
Well I bought my tires for the stock rims I'm going to have for show with my full Wheel covers. There are 5 new bias ply 855-15 b/f tires. One even for the spare. Just like original in the factory photos.
https://www.cokertire.com/855-15-bf-...wall-tire.html
Old 05-24-2017, 11:49 AM   #490
NewType72
NewType72's Avatar
Man do I love a tidy full restoration build. Great work so far and that steering wheel is off the hook!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 05-24-2017, 07:12 PM   #491
chewychevy67
I do like the wheel to. One of my personal favorite pieces. I didn't like the way the brake pedal looked cause the circle around the disc brake plate wasn't crisp so I purchased a 1 1/2" chassis punch and that worked much nicer and a cleaner cut. I also cut the center bar and Tucked it under the plate to clean it up as well.
Old 05-30-2017, 12:01 AM   #492
chewychevy67
I have been thinking what my options are once I do my disc brake swap. The wheels will stick out 3" wider in the front (1.5" on each side) and I don't like that look and I'm keeping the stock gm 15 x 6 wheels. I did some research. You can reverse the centers on the wheels to give you a deeper frontspace. The wheels now have a 3.5" backspace so I found out if you reverse the centers the minimum backspacing you can have is 2" so that is perfect making the wheels stick out 1.5" more than they do now. Perfect. I won't use wheel spacers on this build. You will never know the rears are deeper with the full Wheel covers on. Pictures just show what I'm trying to say. Not my exact wheels.
Old 05-30-2017, 12:17 AM   #493
68bowtie
68bowtie's Avatar
brake pedal turned out great, nice work.
Old 05-30-2017, 12:22 AM   #494
chewychevy67
Thank you. That reversing may still not work as I don't have a good place to put the valve stem where it will stick out of the wheel cover. It will be way inside the rim on the bevel..... Here is the answer for that Maby...
Old 05-30-2017, 12:27 PM   #495
NewType72
NewType72's Avatar
I machined my billet smoothies to have the valve stem on the inside to avoid the constant heat attack from the beating sun at car shows, it's a pain occasionally but a nicely set bead will take care of any constant checking
- Dylan
(209)-985-7721
Old 06-01-2017, 02:54 PM   #496
chewychevy67
Starting to figure out the rear sway bar.
Old 06-16-2017, 07:19 PM   #497
chewychevy67
Tailgate lock. Just playin. Had a gate stolen once and ever since I have been thinking about doing this. Not sure about this. Didn't want to break up the lines on the gate so it had to be hidden by the moulding. It keyed to match my 67 already if I use it.
Old 06-17-2017, 03:09 PM   #498
chewychevy67
Installed.
Old 06-17-2017, 06:04 PM   #499
duallyjams
duallyjams's Avatar
If you could flush mount it no one would even know.
James
IG duallyjams
Old 06-17-2017, 06:09 PM   #500
chewychevy67
If they would have casted the moulding solid instead of hollow that could have been done. I got it as absolutely low as I could. The other option I had was to put a door lock overtop of the handle but that would disturb the clean lines of the rear of the truck. .
