Old 04-17-2017, 04:17 PM   #1
jchav62
1962 C-10
jchav62's Avatar
Trailing Arms question
I have been having some issues with the rear end on my '62. The axle is out of a '72, modified to fit the '62 trailing arms. I was planning on finding another rear end to swap out. Talking to my buddy, he has a '72 rear diff that he's willing to let me have. While b.s.'ing with him, the subject came up about swapping the trailing arms along with the axle. Has anyone done this? Is this even possible? I did some searching, but came up with nothing.
JC62
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-17-2017, 04:25 PM   #2
raggedjim
raggedjim's Avatar
Re: Trailing Arms question
As long as the rear end is from a trailing arm truck, it will work (well, there may be some panhard bar differences) The trailing arms from 60 to 72 are the same.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 04-17-2017, 04:42 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Well I know the trailing arm mounts from 60-62 were wider apart than the 63-72's. That's why I was wondering if the later trailing arms will bolt in place of the earlier ones, swap rear end with trailing arms... not just the axle.
Joseph Chavez
Old 04-17-2017, 04:59 PM   #4
jchav62
1962 C-10
jchav62's Avatar
I just thought of something. It's probably a no go. Being that the '62 frame is wider, the coil springs won't line up.
Joseph Chavez
Old 04-17-2017, 05:03 PM   #5
raggedjim
raggedjim's Avatar
Well, now I'm starting to doubt myself... I had always heard the arms are all the same, but I only have experience with the 64-72 trucks, never the earlier ones. I know the earlier trucks used a different rearend.
Sorry if I confused the matter.
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 04-17-2017, 05:17 PM   #6
raggedjim
raggedjim's Avatar
According to CaptainFab in this thread they are the same, hope this helps, Rg
http://67-72chevytrucks.com/vboard/s...d.php?t=684677
Roger
'70 GMC Jimmy 2wd
Old 04-17-2017, 05:47 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Thanks Roger. They are the same length, but spread out a little wider I believe on the earlier trucks.
Joseph Chavez
Old 04-18-2017, 12:29 AM   #8
Captainfab
60-66 Nut
The '60-'72 trailing arms are all basically the same. The '60-'62's have them mounted farther apart at both the crossmember and the differential.
