#426 |
Re: 8 lug wheels - what's on YOUR truck?
^^ Thanks! The H2 wheels, in fact, require spacers on the rear to clear the Dana60 hubs. Well the wheels actually don't, but the little plastic hubcaps require them.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#427 | |
Thank you, but are you sure about them not fitting a Full float. They fit my 2001 2500hd FF rear end
1985,C20,350,TH400,2.93 gears |
#428 |
#429 | |
![]() Join Date: Jul 2016
![]() I think there is a slight difference in the hub size between the older trucks & newer. Since the H2 & your 2001 HD probably have the same axle, it would stand to reason that they would fit.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#430 |
#431 | |
If you have the Dana 60, I would highly recommend measuring before you buy wheels just to discover the caps don't clear. If you look at the pictures, I have both sets of these hub caps. I learned the hard way that the newer gold and black caps don't clear my Dana 60. I believe they started putting the GM corporate 14 bolt on trucks in the gold and black hub cap era. So I had to spend considerably more for the period correct caps with the blue bow tie - I like them but they are harder to find and usually cost much more unless you get lucky and find a good bargain. In my experience, the Dana 60 full floater is a challenge when it comes to fitting caps, whether they're factory hub caps or center caps that come with aftermarket wheels.
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 ![]() Last edited by 71threequarterton; 04-18-2017 at 12:47 AM. |
#432 |
#433 |
I went with a 16 inch wheel and 265/75 tire to get rid of the 16.5 wheels
#434 |
I have 2002 Chevy Silverado wheels with 265/75R16 tires. I purchased the conversion lug nuts to be able to use the center caps.
1970 Chev C20, 2wd, LB, 350 4BBL, muncie 4spd, 4:10 limited slip. 2002 Chev 2500HD 8.1L Allison, 4X4. 1996 Chev S10 Blazer, 4X4. 2006 Jeep LJ Rubicon |
#435 | |
The Niner
![]() Join Date: Nov 2010
Please, please please don't change the look of your truck. It's perfection!!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#436 |
The Niner
16 x 7 F#rd van rims on 265/75/16 tires
#437 | |
#438 |
Now that I look at my comment, I guess that sounded kind of stupid... After all, I was the one who assumed that if a hubcap fit one 8lug GM truck then it must fit mine too - and I was wrong - they don't all fit.
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 ![]() |
#439 |
I dunno... mine are 17s and they need a spacer. All the power to you if you can avoid it! If you have a different rear end (mine's the D60) then you'll have a different outcome.
#440 | |
I'm pretty sure my truck didn't get any special rear axle. I probably have the "big hub" D60.
#441 |
Agreed.
#442 |
The 8 lug, H2 Hummer wheel will fit the 8 lug DANA 60, Eaton and 14 bolt corporate axle.
The problem is that most hub covers will not fit over the DANA hub. Davepl spaced the H2 wheel out on the rears, so he could use the late style GMC covers and clear the hub. When I picked up my H2 wheels, I bolted them directly to the DANA and spaced the Hummer caps out on the rears. I have since found a good set of GMC covers, but haven't gotten around to either making cover spacers or spacing the wheel out. 2nd picture shows front wheel with standard H2 cover mounting and 3rd with spacer needed to clear DANA hub.
'67 GMC 2500, 292, 4spd, AC |
#443 |
![]() Join Date: May 2010
I've posted several times earlier in this thread but just realized I hadn't posted a picture of the H2 wheels actually installed on my truck.
Just to clarify regarding the recent comments about needing spacers with the H2s on the Dana 60. That's true. However, my tuck has an Eaton axle and did not require spacers to use the 2001-2007 Chey/GMC caps on the rear. Incidentally, I still prefer the H2s on my truck. Perhaps, it's the color contrast of white wheels and maroon paint or the fact I'd looked at the white wheels for 48 years. Last edited by FirstOwner69; 04-19-2017 at 10:38 PM. |
#444 | |
Who Changed This?
![]() Join Date: Jan 2013
#445 |
I suppose a quick internet search would be in order so we could each identify which axle we have.
#446 |
So how are spacers made for the caps to fit over a Dana 60?
#447 |
got some external thread lug nuts now...
#448 |
If I have a Dana 60 8 lug rear on a 2 wheel drive C20.... is it safe to use 1.5 inch thick wheel spacers ( the kind that bolt to the hub and have their own lugs/studs)? i have 14.5 mil on the front and 1/2 lugs on the rear and would like to match them up plus be able to mount hub caps or center caps
#449 | |
Perhaps davepl can provide further info on what he used with his H2 wheels. |
#450 |
Few pages back I put a pic up of my bare f*rd accuride wheels.
here they are finally on the truck with 245/75/16.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
