Old 04-17-2017, 11:59 PM   #1
KyleSeal
KyleSeal's Avatar
Radiator Questions!
Well Im in the assembly stage (finally) of my 70. So this brings lot of questions to mind during assembly.
The main one I'm battling right now is the radiator fitment. I have a new core support in my truck from LMC, which actually is working out very good, but the radiator I have (came with truck when bought, looks 'stock') does not fit. Ive read some info on HD mounts (upper/lower) but am still left with some questions.
Does this core support not have the HD lower mounts? What is the measurement for the HD lower mounts? Also, does my radiator look stock? The P/O had removed the lower mounts, bolted (literally) the radiator to the core support and used angle iron to hold it in place, so I have no original reference of fitment with it. See attached photos.
I'm not afraid to cut and install new ones, but before I cut up my nice replacement support I want to know for sure. Also, if it comes down to it and I need to just have something that works, would a 2 or 3 row work okay for a mild cam/stock bottom end 350 V8? Average summer temps in VA are 90-100 June - August.
Thanks in advance.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 04-17-2017, 11:59 PM   #2
KyleSeal
KyleSeal's Avatar
Re: Radiator Questions!
More pics.
Toano VA
Old 04-18-2017, 12:05 AM   #3
toolboxchev
It appears to me that your radiator is not for your truck. The bottom return is the give away. It should turn toward and up to the center...yours appears to be out out the square body era and your mounts are for a three row radiator possibly.
toolboxchev is offline   Reply With Quote
Old 04-18-2017, 12:16 AM   #4
MIKE77z
MIKE77z's Avatar
Doesn't look right to me either, i have a 2 row aluminum replacement from northern rad it fits in the 3 row brackets that came with the blazer that rad you have pictured looks like a rad out of a 6.2 diesel square body truck to me ( those are a 2.5 inch core ) but i could be wrong.
MIKE77z is offline   Reply With Quote
Old 04-18-2017, 12:30 AM   #5
In The Ten Ring
I'm facing the same problem. My replacement core support came from a 1970 big block'ed truck and I think all my replacement radiators have lower bracket problems. I may have to fab up something.
I am tempted to order a custom, USA made radiator. "Buy American, hire American, the Trump Effect."
In The Ten Ring is offline   Reply With Quote
Old 04-18-2017, 10:00 AM   #6
B. W.
B. W.'s Avatar
It looks like your lower rad mounts are 3 core, need 4 core mounts, the rad support must be "massaged" to fit the 4 core mounts. 1st pic is 3 core, 2nd is 4 core.
B. W. is offline   Reply With Quote
Old 04-18-2017, 09:49 PM   #7
In The Ten Ring
Whoa! Easy solution I guess. Thanks for the pic.
What vendors here carry 4 row lower brackets?
Old 04-18-2017, 11:22 PM   #8
Z10
Z10's Avatar
I have this installed in my 72GMC
http://www.speedcooling.com/1967_197..._Radiator.html
Great price and it fits like a glove. I've got 11k miles on it Hot West Texas with zero issues. You can see more pics in my build thread.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-18-2017, 11:37 PM   #9
B. W.
B. W.'s Avatar
GMC Pauls, upper bracket 213422, lower 213423, rubber pads 213424. LMC should have them too.
Old 04-18-2017, 11:48 PM   #10
In The Ten Ring
Hmm. I may actually have those already just not mounted to my core support. Once I get back onto the truck I'll have a look but if not, I'll order some. Thanks!
Old 04-19-2017, 12:22 AM   #11
In The Ten Ring
Thank you. I have three replacement radiators already....that is one area where I took in lots of advice from the site and still haven't found a perfect fit. "Spare parts" is how I view it.
It may just be that I have three row brackets on the bottom, those came attached to the core support. I'll have a look into 4 row lower brackets and go from there.
Old 04-19-2017, 12:55 PM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 04-19-2017, 01:09 PM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Bingo, I just went through this. Assuming 4 row radiators were standard with 402 blocks, GM neglected to bend the support so the brackets sit flat.
A crescent wrench works real well OP.
Before:
After:
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-19-2017, 01:52 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Mine had a bolt attached to the bottom of the mount that goes through the support but I was lucky, I had four core mounts already installed. I have a three core and a four core radiator but I didn't have the four core top mounts so I used the three core. It was in when the PO had it and it worked fine so I am going to use it.
Also I lost one of the rubber inserts for one of the top ones, and I got creative and taped the support up and filled it with RTV silicon, and it works great.
Then I found the original!
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-19-2017, 04:14 PM   #15
71CHEVYSHORTBED402
Whether it was factory or a mechanic I once used, I believe the fact the bottom brackets weren't fitted contributed to one of my top brackets coming apart at the spot welds. I bought all new brackets, repro., from Olympia Wa. guy. Nothing special about original brackets.
Old 04-21-2017, 12:06 AM   #16
KyleSeal
KyleSeal's Avatar
HERES THE SOLUTION (I'm the OP'er and I found my solution): my radiator is a stock style 4 row radiator. My LMC core support (in my original post pics) had 2-3 row lower brackets. I needed to get the 4 row lower brackets. A friend of mine had lower brackets from a 1-ton truck, so I removed them and installed them on mine (massaging needed as stated above) and the radiator fits great and is ready to be run. Parts vendors do sell these brackets and they are labeled as "HD brackets".
Toano VA
Old 04-21-2017, 01:03 AM   #17
In The Ten Ring
I love the "HERE'S THE SOLUTION" in all caps, it's like something I would type.
HD brackets huh? I am going to have to do that in the next week or so, it's high time to get my truck ready for assembly! Thanks brother!
Old 04-22-2017, 04:28 PM   #18
KyleSeal
KyleSeal's Avatar
Not a problem, IMHO theres too many threads where guys asks questions, figure it out on their own and never come back with their answers!
Toano VA
core, hd mounts, heavy duty, mount, radiator
