Old 04-06-2004, 09:58 AM   #1
Chevelle454
Chevelle454's Avatar
Does this just pull off?
I am taking the cluster out. Does the knob for the headlights just pull off? I am pulling really hard and it is not budging...
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 04-06-2004, 10:04 AM   #2
meathead95
computer illiterate
meathead95's Avatar
reach up in behind the dash on top of the switch is a spring loaded button push it down and pull out the knob
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-06-2004, 11:38 AM   #3
Chevelle454
Wow, I can't believe how well you guys know these trucks...
How do I get the ignition out and the cigarette lighter? It's a '72 if it matters...
1972 C10
1972 C20
Old 04-06-2004, 11:52 AM   #4
dubie
dubie's Avatar
ignition switch removal
and
Removing lighter
Hope this helps you out bud.
And yes, we all know these trucks in and out so don't ever be afraid to ask questions, thats how you get to know these things
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-07-2004, 05:29 AM   #5
jimfulco
After you pull that knob out, check & see if your lights are on.
jimfulco is offline   Reply With Quote
Old 04-07-2004, 10:42 AM   #6
Chevelle454
It's just a cab, I am taking everything out for paint. I still can't figure out how this ignition switch is supposed to come out...maybe mine is just corroded or something. I can't get it to move.
1972 C10
1972 C20
Old 04-07-2004, 10:44 AM   #7
dubie
dubie's Avatar
I had a hard time with mine to. I ended up giving it a small squirt of WD-40 and it loosened right up. The actual key center part will come out separate from the ring bezel. Just keep at it, it will come out
