Old 04-21-2017, 10:42 AM   #1
Carystone72
1970 four wheel drum breaks.
I have a 1970 k10 I just did the drums all around and was wondering if they are self adjusting, the truck pulls hard left when I hit the brakes, I replaced axle seals, brake cylinders, hardware and shoes and I thought I had it adjusted correctly. Anything helps thanks.
Carystone72 is offline   Reply With Quote
Old 04-21-2017, 10:45 AM   #2
BILT4ME
Re: 1970 four wheel drum breaks.
When you were in there doing the brakes, did you see if there were self adjusters on the shoes? If so, there is an arm that covers the star wheel. They adjust when backing up.
Also, you should adjust the brakes up tight, then back them off 12 clicks (I think) on each wheel. This will set them properly from the get-go. This also makes them even from the start.
Do you have a FSM? If not, get one. They're on here electronically for free.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 04-21-2017, 11:39 AM   #3
demian5
demian5's Avatar
Originally Posted by Carystone72 View Post
The truck pulls hard left when I hit the brakes.
If you are sure you adjusted everything properly and rechecked, then:
  • Check tire air pressures that they are even.
  • Look for a bad steering or suspension part.
  • Understand that drum brakes suck and this is part of having them
  • Make sure you don't have a partially plugged brake hose on one of the fronts.
Put truck in air and have someone press brakes at different pressures (and hold) and go to each wheel and spin (put truck in neutral). The one that isn't grabbing as well will become obvious. The different pedal pressures and hold will help determine if its a restricted hose as the fluid will eventually actuate the brakes, but it takes longer.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-21-2017, 12:33 PM   #4
toolboxchev
Do not give up in frustration on your original setup. I have had the drums on my 70 for over 11 years with a loose front end.
Just go through the brakes again making sure all is working properly. Mine stop so good a stupid kid ran into my rear bumper totaling his Honda.
So do they work???? It is one of the easier systems on these old rigs to rebuild or repair, Its all mechanical.
toolboxchev is offline   Reply With Quote
Old 04-21-2017, 01:35 PM   #5
weq92f
weq92f's Avatar
I have to agree that you system should work fine once adjusted.
Manual adjust drum brakes..
Assuming all up top and hoses are good... Pull off the drum and manually adjust the shoes out so that the drum fits over the shoes, but barely. When wheel is on continue the adjustment through the slot in the drum with a big screwdriver or adjusting tool. Adjust tighter until the wheel still rolls 'freely' but with a ~small amount~ of drag. Even if the drag initially is uneven and sounds completely wrong. Get both sides front and rear to this point and then go drive it. Mash it pretty good to seat everything. Repeat the adjustments until if feels right, drive for a few days and adjust again.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-21-2017, 03:17 PM   #6
LongBox
Keep at it. Manual drum brakes can and do stop these old trucks, and in a straight line to boot. While I cannot deny the advantages of disk brakes, good drum brakes will do the job.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 04-21-2017, 11:02 PM   #7
saxart
saxart's Avatar
Did you replace the self-adjusters? If so, they are side-specific, so make sure you have them on the proper side of the vehicle. (Also confirm that you don't have two that belong on the same side)
Secondly, don't accept "good enough" with these brakes. There seems to be some level of hate for drum brakes around here, but if they're working correctly, there's no reason you can't have a great driving (and stopping!) vehicle.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
