Old 04-23-2017, 03:09 AM   #1
WB72
Before and After
WB72's Avatar
Frame paint decisions...
What are you guys using for frame paint,
I have heard these have been used:
POR-15, and similar,
Regular enamel paint,
Undercoating,
Bedliner
What sheen is best?
Gloss, semi gloss, flat or textured?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 04-23-2017, 04:19 AM   #2
OregonNed
OregonNed's Avatar
Re: Frame paint decisions...
My choice was POR 15 with its associated top coat. Worked out strong and durable for me. I also used it on the underside of both front inner fenders and rear wheel housings.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-23-2017, 04:50 AM   #3
In The Ten Ring
1). Is POR 15 brushed on?
2). My front inner fenders are epoxy primed, would POR 15 work well coating that?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 04-23-2017, 05:27 AM   #4
WB72
Before and After
WB72's Avatar
Did you use hi gloss or semi gloss?
66,000 miles.
Alberta, CANADA
Old 04-23-2017, 08:28 AM   #5
FRCvette
I built a street rod truck a few years ago and used Massey Ferguson paint for the frame. I painted the truck torch red and the MF matched it pretty well. Bought it at local Tractor Supply for around $7 per quart. Can spray or brush on. They also have it spray cans too. Held up pretty well.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 04-23-2017, 11:29 AM   #6
kaycee
kaycee's Avatar
Tractor paint = rustoleum with some hardner used it on my inner fenders and such still looks good after 7 yrs.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-23-2017, 01:23 PM   #7
OregonNed
OregonNed's Avatar
Thanks!
Yes I brushed it on. It flattened out well. I made sure that all my metal surfaces were prepped per their instructions so I have no experience in painting over any other coating.
Old 04-23-2017, 01:25 PM   #8
OregonNed
OregonNed's Avatar
For a top coat I used the semi glass. Most of it was sprayed but I also used some of the brush on topcoat.
Old 04-23-2017, 01:35 PM   #9
davepl
davepl's Avatar
I powdercoated mine.
It always makes me think of my 2+2 (in this month's Hemming's Muscle Machines, btw!) which was restored at Musclecar Restoration in WI. They go all out... they putty, fill, and block sand the frame. It looks like it was laser cut and welded, a fresh brand new stamping.
My truck isn't bad because it was never very rusty, so it's not pitted, but the Pontiac was. It would never have occurred to me to visually "restore" the frame stamping! But it looks swanky... it's "over-restoration" at its finest, but looks amazing.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-23-2017, 01:42 PM   #10
OregonNed
OregonNed's Avatar
I didn't take any pics of the frame but here are a few of other components I treated. Inner fender
Old 04-23-2017, 01:43 PM   #11
OregonNed
OregonNed's Avatar
Plate frame, bumper brackets
Old 04-23-2017, 01:44 PM   #12
OregonNed
OregonNed's Avatar
Diff cover
Old 04-23-2017, 01:44 PM   #13
davepl
davepl's Avatar
Looks as good as my powder did, at least in photos. Nice job!
Old 04-23-2017, 01:45 PM   #14
OregonNed
OregonNed's Avatar
And cross sills
Old 04-23-2017, 05:38 PM   #15
57taskforce
All about them K’s
57taskforce's Avatar
I'm getting ready to paint my frame with chassis saver. Supposed to be pretty good stuff.
Tyler
Old 04-23-2017, 06:40 PM   #16
kaycee
kaycee's Avatar
I shot chassis saver on my Impala frame seems to be pretty durable I would use it again for sure. I would use the tractor paint again also ,for a weekend warrior or everyday cruiser most economical .
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 04-24-2017, 09:15 AM   #17
WB72
Before and After
WB72's Avatar
I heard it is very similar to POR 15. It is about $225/ gallon here in Canada.
66,000 miles.
Alberta, CANADA
Old 04-24-2017, 09:18 AM   #18
WB72
Before and After
WB72's Avatar
Tractor paint? Never heard of it, but will research it locally. $7/ qt is a lot cheaper than POR15.
66,000 miles.
Alberta, CANADA
Old 04-24-2017, 09:19 AM   #19
WB72
Before and After
WB72's Avatar
That looks great.
66,000 miles.
Alberta, CANADA
Old 04-24-2017, 09:34 AM   #20
57taskforce
All about them K’s
Wow that's crazy! I just paid less than 80 for a gallon down here.
Tyler
Old 04-24-2017, 10:17 PM   #21
kaycee
kaycee's Avatar
I paid $27 a quart for chassis saver used 2 , tractor paint I got at tractor supply about $15 a quart about the same as rustoleum paint in the quart can.
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 01-04-2021, 08:34 PM   #22
tinman_local2
Van Sickle is what TSC sells and if you use the hardener it is tough as nails. Flows out good, but is single stage and a little harder to paint as far as orange peel and runs go. Nothing you can't eliminate by setting up your gun correctly.
tinman_local2 is offline   Reply With Quote
Old 01-04-2021, 09:23 PM   #23
Furno68C20
Undercoating,
Bedliner
What sheen is best?
Zero Rust is what I’ve heard is good. It can be thinned out and It’s store nicely too unlike por15 which is one and done once you crack a can.
Brush or roller on.
Furno68C20 is offline   Reply With Quote
Old 01-04-2021, 10:12 PM   #24
70STOVEBOLT
70STOVEBOLT's Avatar
Rustoleum low gloss black farm implement paint in brush on quarts and spray cans to get full coverage. It was very time consuming, as I left the cab on and the rear suspension on but it looks good and has held up well. It also cost me less than $100 for 3 full coats.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-04-2021, 10:30 PM   #25
May70
May70's Avatar
I have used por15 and KBS systems. In my experience KBS is far better than por15 and por15 is way overpriced for what it is.
Por15 is somewhat known to have major adhesion issues if its fairly clean metal or in other mysterious circumstances. Either way both are single part systems. The best will always be 2 part.
AND I still find myself shocked at those who would spend grueling hours prepping a frame to put a $15/quart rustoleum on it (even with hardener). Mind boggling concept. If you are going to go the cheap way out, just douse the thing with oshpo and then rattle can it, you will have better lasting results.
No one talks about the fade and rust through cheap paint *cough* rustoleum leaves you with in a ~1-2 yr time frame. Cut that by 1/4 if you actually drive it and typical road gravel etc get thrown into it. Even a polished turd will shine for a little while...........
Spend ~150 more bucks and get a two part system, two full wet coats of sealer then paint it with your $15/gal stuff. In 15 years your frame will look better than the rustoleum job that's a year old.
Sorry if it seems like a rant but you get what you pay for, paint is by far the one of the worst exceptions you could make.
Oh and..... adding the so called 'hardeners' to cheapo paints is not the equivalent to adding an activator to a two part system, not even close.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
