Old 04-25-2017, 11:03 AM   #1
WarMonger
WarMonger's Avatar
Intake manifold preference
Soooo finally pulled the intake. this turd has been leaking since I built it. What gasket set do you guys recommend? I only want to do this once. Well twice now, but whatever. I don't want to do this again. What have you guys had luck with?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 04-25-2017, 11:16 AM   #2
68is4me
68is4me's Avatar
Re: Intake manifold preference
Fel-pro's and I don't use the rubber seals that go on the block. Just a bead of good sealant.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 04-25-2017, 11:23 AM   #3
randy500
I'm chiming in here but am sure I will get flamed for my answer...
I would never use those end seals since they don't allow for clearance that may be needed for the intake to sit where it needs to seal up on the intake and water ports, it can be too short or too tall which will prevent a good seal, I think the best practice for the last 20 years or more is to use RTV, a bead about 1/4 to 3/8" high set towards the outer side on each end to allow it to squish in towards the valley without too much excess inside.
I also like the very cheap felt, non embossed intake gaskets, don't know the brand but everytime I have removed them they separated in the middle because the were stuck to the intake and the head....don't know the brand.
I have used McChord and felpro with good results though. You will get oil leaks through the bolts on the intake if you don't put sealer on the holes which are not blind tapped.
randy500 is offline   Reply With Quote
Old 04-25-2017, 11:26 AM   #4
WarMonger
WarMonger's Avatar
Like RTV for sealant? Blue stuff?
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 11:28 AM   #5
randy500
Black RTV, it just looks better...
I will add though that I think the embossed gaskets with the slick coating are made for a reason, so the intake can slide against the head and keep a seal when it expands and contracts at a different rate. So that style is probably more reliable.
Old 04-25-2017, 11:34 AM   #6
WarMonger
WarMonger's Avatar
So maybe embossed gaskets with silicone on them? yes... no...
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 11:36 AM   #7
WarMonger
WarMonger's Avatar
can you get the fel pro's at any parts place? Or do you have to order them?
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 11:38 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Use this for the end seals. A bit spendy but worth the money.
Are you leaking coolant? Or oil? Or both? I always use a little Gasgacinch on the heads and the gasket face (towards the heads) to get them to set up and stick to each other so they don't move when I lower the intake down onto them. No Gasgacinch on the intake or other side of the gasket.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-25-2017, 11:43 AM   #9
WarMonger
WarMonger's Avatar
Gary
it was leaking oil out passenger rear corner down onto the starter.
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 11:47 AM   #10
GASoline71
GASoline71's Avatar
The black RTV that I posted will cure that. Use no lifter valley wall gaskets and run a 3/8" thick bead of the black RTV on top of the wall. The can that The Right Stuff comes in is pressurized, so it makes laying a bead a snap.
Gary
Old 04-25-2017, 11:55 AM   #11
WarMonger
WarMonger's Avatar
thanks Gary. Do you like the Fel Pro's also?
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 12:08 PM   #12
GASoline71
GASoline71's Avatar
When bolting on an aftermarket aluminum intake I usually use the Fel-pro intake gaskets that are not of the "Permatorque" variety. I've also used intake gaskets made by Cometic, Victor, and whoever makes the gaskets for Edelbrock. Actually all of them have worked just fine over the years.
Gary
Old 04-25-2017, 12:09 PM   #13
WarMonger
WarMonger's Avatar
thanks for all the info guys. I will keep you updated on the back together part also.
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 01:05 PM   #14
I may get flamed for this, but...
My machinist does a lot of performance engines and says he's had worse luck with Edelbrock intakes than Chinese knock-offs sealing. He won't just bolt one on. He resurfaces them all. I agree, valley gaskets do more harm than good. They made me think I was a worthless mechanic after being careful and thorough and they always leaked. They should just leave them out and reduce the cost $.20
Old 04-25-2017, 01:33 PM   #15
webfoot
I like the fel-pro printoseal gaskets.
x100 on not using the end gaskets.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 04-25-2017, 01:58 PM   #16
GASoline71
GASoline71's Avatar
Which is the main reason I won't use Fel-pro Permatorque intake gaskets with aluminum intakes. Now even Edelbrock says in their intake manifold installation instructions to not use a "permatorque style" intake gasket. Since stock iron requires more TQ of the fasteners than aluminum the permatorque gaskets never squishes to it's proper thickness with aluminum intakes. At least what I was told many moons ago by an old drag racer. Old bench racing tales can be as wild as old wives tales... so...
Gary
Old 04-25-2017, 02:24 PM   #17
biketopia
The last few times I've bought a set of fel pro intake gaskets they came with a small tube of RTV instead of the end seals. Sounds like everyone else has gotten you squared away.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 04-25-2017, 02:33 PM   #18
WarMonger
WarMonger's Avatar
Now I have an assault intake manifold on it. What should I use for torque specs?
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 04:01 PM   #19
WarMonger
WarMonger's Avatar
Torque specs on intake anyone?
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 04:28 PM   #20
WarMonger
WarMonger's Avatar
i got it. 25 ft lb's in 2 steps. Funny thing, there is this search box you can type stuff in at the top of this website. boom, mind blown
1970 C20
-_--_--_- ______
1972 K5
Old 04-25-2017, 05:10 PM   #21
biketopia
There you go, glad you found it! Remeber put some kind of sealant on the bolts that go into open holes or you'll have more leaks. I've always just used Teflon tape.
Old 04-25-2017, 05:30 PM   #22
wbc409
Make sure you overlap the rtv and intake gaskets in the bottom corners where the heads and block come together. Just a little bit though, all you want to to do is take up any tolerances, and make sure the corners don't leak.
wbc409 is offline   Reply With Quote
Old 04-25-2017, 05:50 PM   #23
midniteblues
midniteblues's Avatar
Only the four corners are blind holes the rest open into the valley.
There is also a few that if a longer than standard bolt is used will bind up the push rod.
Also I perfer to use studs when I can for the dizzy hold down, throttle cable bracket, carb and sometimes the water neck. Alot less chance of pulling out aluminum threads.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 04-25-2017, 06:01 PM   #24
67ChevyRedneck
67ChevyRedneck's Avatar
Gary
I spent the extra couple bucks and bought the "edelbrock" gaskets. Edelbrock gaskets don't come with end gaskets, they tell you to do a bead of sealant like everyone is suggesting.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
