Old 04-26-2017, 03:25 PM   #1
62lwbc10
Tung oil for bed wood?
Hello all I just received my brand-new Bed wood from mar k. Went with Oak. I'm now starting the task of figuring out what kind of finish to apply. Durability and resistance to weather is not that much of a concern to me because my truck will likely never see any kind of precipitation. Someone mentioned using tung oil rather than the typical Marine or spar varnish. Wondering if anyone has any experience. Thanks in advance
62lwbc10 is offline   Reply With Quote
Old 04-26-2017, 06:50 PM   #2
OrrieG
OrrieG's Avatar
Re: Tung oil for bed wood?
This has been discussed a lot, please use the search box above to find the old threads, if you are still confused check back.
Old 04-26-2017, 08:18 PM   #3
62lwbc10
You're right Orrie my bad
Old 04-27-2017, 08:22 AM   #4
Port&PolishMan
Port&PolishMan's Avatar
Tung Oil is OK - More Important is using White Oak - instead of - Red Oak ..
Furthermore then the UV - considerations ..
I went with : Tung / Linseed with 30 % Sealer . 2 Coats , then Applied Third Coat
with 50% More Sealer Added to the Above Mix .. MinWax - UV Exterior - had Stored Wood Tool Cabinet 18 yrs. 1 Gallon all Oil . .
Port&PolishMan is offline   Reply With Quote
