03-10-2017, 05:46 PM | #26 | |
Re: window sweeps issues
I can't wait to try them. everything else I have tried have been garbage.
03-10-2017, 06:40 PM | #27 |
The window won't close completely because the bracket on the outside of the lower window frame (2 of them) hits on the new fuzzy. The solution is figure out where those two brackets hit and grind reliefs the new outside only Chinese fuzzy so the window will close. The clips are so cheap that you can't take it off and on too many times or it breaks, though.
Good luck. Love that Chinese stuff!
Everybody has to believe in something. I believe I'll have another beer. |
03-10-2017, 07:04 PM | #28 | |
03-10-2017, 08:20 PM | #29 |
The metal "L" brackets at the bottom of the glass it what hits the cheapo felts.
03-13-2017, 02:28 PM | #30 | |
03-13-2017, 02:29 PM | #31 |
03-17-2017, 12:20 PM | #32 |
04-28-2017, 11:19 AM | #33 |
04-28-2017, 11:29 AM | #34 |
That project is on hold right now. I might end up removing the clips and screwing them in with little crews so that they sit higher in the window frame. They function for now but I am not happy with how they function.
04-28-2017, 11:37 AM | #35 |
I leave them for last because I absolutely dread doing these on every truck I do. They are a complete PIA. The screw method has worked the best for me, but it is tough drilling the holes with it painted and getting the bit not to walk. I get little black screws from Ace Hardware and you can't even see them in the sweep. Buy a couple bits so they are nice and sharp for drilling and pull it out as far as you can in the chuck.
04-28-2017, 11:48 AM | #36 |
In order to keep it form walking can you drill the hole in the sweep first and then tape or clamp it into place in he window and use the holes in the sweep to keep it from walking.
05-01-2017, 08:34 AM | #37 | |
05-01-2017, 09:44 AM | #38 |
That's fine if you remember to do it before you paint, but have you ever tried to find all those tiny holes through 1/8" thick fuzzy stuff?
05-01-2017, 11:05 AM | #39 |
What size if hole do you drill and what size of screw?
05-01-2017, 08:15 PM | #40 |
I think I posted this before but this is what I did to correct the window from going to the top. I put new sweeps in my 66 and had same problem . I took the window out of the lower glass setting channel and tapered the top edge front to back and do both side's of the channel.I used a flap wheel on a electric grinder as the flap wheel will leave a smooth edge on the taper .Make it about 45 degree's. Then you can rattle can paint it to keep fron rusting. Then reinstall the glass in channel. This let's the channel squeeze in between and up all the way ,rather than having a sharp edge to wedge against sweep's and bind . I have no problem rolling window to the top whatsoever ever.I think I got my sweep's from LMC which probably make's no difference where I got them,since some of you have tried different brand's.
05-01-2017, 10:11 PM | #41 | |
Thanks that makes a lot of sense I will give that a try. Either I did not see your post befor or I did not quite understand what you were saying.
05-01-2017, 11:15 PM | #42 | |
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
05-03-2017, 03:15 PM | #43 |
Moderator
Anyone try Metro's sweeps yet?:
http://metrommp.com/?f=detail&ModelN...l=C10%20PICKUP
05-04-2017, 08:25 AM | #44 | |
05-04-2017, 09:15 AM | #45 |
Moderator
Steele Rubber Products is even more: http://www.steelerubber.com/wflt-f26...4-6-80-0059-57
But I don't know if one is any better than the other.
05-04-2017, 10:16 AM | #46 |
Moderator
The Repop company part #CT160 on this page: http://www.repops.com/product-search...2&mo=102&yr=19
05-04-2017, 11:19 AM | #47 |
I have tried the Repops and the Steele Rubber and they are both the same and have the same bad design.
05-04-2017, 12:29 PM | #48 |
Repop's are repop's period.Most likely all the same. Mounting those with screws and higher is not necessary. Maybe with screw's would be a good idea if you planned to remove easier if needed in the future and would not break clip's otherwise. I used the clip's that are on the sweep's and only beveled the channel's and have no issue with raising window to the top. Maybe the original sweep's were made different, don't know ,but do know when I replaced sweep's that is when I encountered the window issue.
05-04-2017, 12:42 PM | #49 |
Moderator
I'd like to see an original outside sweep, I bet it was a type of wiper.
05-04-2017, 01:05 PM | #50 |
No, I have a original extra door I bought years ago and they have the same design what I can see from the top.
