Old 04-28-2017, 04:50 PM   #1
tim71
tim71's Avatar
Rebuild Sequence
Went to the body shop yesterday with my rolling frame/engine,tranny and tr ansfer case. Cab was lowered and put back on frame. We also put the doors back on. Question...is there a preferred sequence to start my rebuild? Especially all the items under the dash. I've also considered getting the core support on so I could get the radiator on and plumbed in, I'm anxious to start the engine. Fenders,cowl,hood and bed aren't painted yet.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 04-28-2017, 05:25 PM   #2
kwmech
Re: Rebuild Sequence
I would start with the pedal assy and the steering column and work my way to the right. There is a ton of work before you get the front section
Old 04-28-2017, 07:53 PM   #3
Husker
Husker's Avatar
Nice So Far.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 04-28-2017, 08:15 PM   #4
72 tigger
72 tigger's Avatar
I've only done a couple, but I start with anything that mounts to the interior side of the firewall & work my way towards the dash- if that makes sense? Did you take disassembly pics? A donor truck (that isn't gutted) is helpful too
72 tigger is offline   Reply With Quote
Old 04-28-2017, 08:48 PM   #5
tim71
tim71's Avatar
Unhappy Re: Rebuild Sequence
I took a lot of pictures before I disassembled and them some as I was disassembling. Mostly took pictures so the final reassembled truck would look and function as truck did originally. As usual I gave my memory ability to much credit on what order I took truck apart. Mostly I'm just looking for some advice on what the best sequence of reassembly would be. I don't want to install something only to have to remove it because something else needed to go in first. Fortunately I have a lot of time and patience.
Old 04-28-2017, 09:24 PM   #6
72 tigger
72 tigger's Avatar
Did you do a search on the forum for the sequence? Put the dash pad on early so that you can access the nuts.
