#5251 |
![]() Join Date: Jan 2016
Re: What did you do to your truck today? Chapter II
Nice! Sea ten
#5252 |
Working on a spare tire mount that tucks it in the front right corner of the box
#5253 |
![]() Join Date: Mar 2016
Started the removal of the old cracked sealer and clean up of the drip rail so it can be resealed soon. Also this week, installed a new fan shroud to keep it cool for the summer and got it tuned pretty well now. Of course, I discovered the previous owner had the center link installed backwards, but one thing at time... Lots of things to do, but at least progress is being made.
#5254 |
![]() Join Date: Dec 2012
Cleaning up gauge wiring today and a new temp sender
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#5255 |
Swapped out the faux wood Grant GT wheel for an actual old school Superior "the 500" wheel:
#5256 |
I had a busy day yesterday. All by myself.
Pressure washed and sold the engine.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
#5257 |
Hey Glenn, if you don't mind me asking, how much did you get for the straight six motor? I have one in good running condition that I'm trying to sell. Thanks.
Hey man ![]() 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
#5258 |
For the 250, I asked $500 and got $350 within a few hours. I kept the flywheel, clutch and alternator. I may have left some money on the table, but I just wanted it to go away quickly. The buyer offered $300 and I countered with $350. I would have taken less.
#5259 |
Finally got her out of the weather. Gutted and rebuilt the one car garage. My wife and I started this project over a year ago. But we took some time off to gut and remodel our master bathroom, so this one got delayed. Now safe and secure and dry. Just in time for the rainy season here in Florida.
#5260 |
thanks bro!
#5261 |
Nice job on the truck shelter.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#5262 |
I found these lying under the truck.
It took an hour and a half for them to fall out. 3 cross members, 2 rear shock mounts, 2 rear bump stops, 2 ball joints and 1 Z-bar mount. A good air hammer, high pressure from the compressor and a new bit made it fairly easy. Thank you Snap On.
#5263 |
Finally got my rally's swapped out with the new Cucv blazer rims. Got a lot of input from everyone here before choosing route to go. Hubcaps look great on them as well. Thanks all.
#5264 |
I finally took the time to get up under the dash to fix some things.
I hooked up ground wires to the tach an dash panel, and hooked up the wire for my tilt column shift indicator light. Everything works! ![]() It's been a good day ![]() |
#5265 |
Indeed, just in time! Nice plate. (Go Gators!)
#5266 |
#5267 |
Tried to fix my driver door windows. Welded the pivot post back onto the wing window frame, riveted new seals in, welded the kept nut on the rear window track guide, installed new rollers, and now the window won't roll up past 1/2 way
![]() Maybe tomorrow will be profitable. Today was a loss. Mounted/gapped the hood yesterday, so the week has been 50/50, so far.
1972 C20 Fleetside "Miss Olive" http://67-72chevytrucks.com/vboard/s...d.php?t=721563 |
#5268 |
Awoke this unfinished project and took it for a putt putt through town.
Now that my 4x4 is mobile I need to get back on this.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#5269 |
Today, I finished the New Flxplte and Starter Project. When I hit the key
It sounded better than it ever has. It sounds like a new truck. I also put the Power Plate in my carburetor, and man what a difference! ![]() |
#5270 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Yesterday I installed the dual snorkel Air Cleaner I got from Rock Auto. I had to to do a couple tweaks like remove the Oil Fill Tube and plug carb hole where hose from heat thing went.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#5271 |
I like that, looks clean. Could you give me the part number or more info? Thanks.
#5272 |
Big Block
Love the dual snorkel air cleaner. Nice upgrade.
#5273 |
20' Daredevil (Ret)
![]() Join Date: May 2003
x3 on the dual snorkel air cleaner, very nice!!
Got my new drag link and tie rod ends installed, and I'll have the alignment checked next week. Nice to have the 45-year-old steering parts finally replaced.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#5274 |
Yes for sure. Its listed under a 1972 Camaro with a350 4bbl engine as an Air Intake Kit and the Goodmark part # is GMK4021230704SX. You can also get them with achrome lid but I want my truck to look kinda stock under the hood. Was about 175.00 US
#5275 |
blasted and painted the frame today.
