Old 05-01-2017, 01:10 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Ls swap donor...what's needed?
I just recently acquired an 01 2500hd with 6.0 and 4l80 tranny. What all do I need to pull off the donor truck to do the swap. Momma doesn't want this truck sitting in our driveway long(body is very rough)! Please help don't want to get rid of anything I'll need.
tex_waco_usmc is offline   Reply With Quote
Old 05-01-2017, 02:29 PM   #2
nastety92
Re: Ls swap donor...what's needed?
Engine
Engine wiring harness
Transmission
ECM / PCM
Gas Pedal
Air Intake if your going to use the stock one
Might as well keep the fuse block under the hood
Overflow tank
Mechanical fan if your going to run that
On my swap I'm trying to make it look 100% stock under the hood. Other people have done custom air intakes and electric fans.
Also is the truck going to be 4wd or 2wd in the end?
Good luck,
Nick
nastety92 is offline   Reply With Quote
Old 05-01-2017, 02:42 PM   #3
tex_waco_usmc
2wd in a short bed 67. Do I need cross members, etc?
Old 05-01-2017, 02:42 PM   #4
nastety92
Is the 2500HD 2wd or 4wd?
Old 05-01-2017, 02:53 PM   #5
t300
If you really want to get everything you can off it it then add throttle cable, cruise control box and cable, rear view mirror and temp sensor/wiring, I used a bunch of the exhaust piping to build my exhaust as well. 7pin trailer wiring, hitch may be able to be used. Saw a post here where someone used the rear brake calipers with a custom bracket. Apparently door molding can be used. Some have used the front bench seat or buckets.
t300 is offline   Reply With Quote
Old 05-04-2017, 09:15 AM   #6
tex_waco_usmc
2wd
Old 05-04-2017, 12:45 PM   #7
69gmcc10
69gmcc10's Avatar
I have an 01 1500 sitting in my driveway for the same purpose and it has been there for a year and 4 months, my wife is not impressed. I am very close to getting the engine swap part of the project completed, I have to install the wiring loom I cleaned up on my own and run fuel lines and I should be done with the donor truck.
From the donor truck I have used the engine and trans, the power steering cooler, trans cooler, trans lines, wiring harness for the engine, the fuse block. I am going to try and use the in cab section of the wiring for the cruise, cluster, & obdII. I also used the radiator air intake, coolant overflow, computer mount, cruise control box off the fire wall, and throttle cable. Before I junk the truck I am going to snag the front seats to retrofit and I am going to see if the carpet will fit (I have a high hump). Other things to consider are maybe the fuel door (if you plan to put the tank out back) and the cruise switch from the turn indicator if you are going to install cruise.
good luck
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 05-04-2017, 12:59 PM   #8
Jstock85
good luck
What you doing for your fuel system?
Jstock85 is offline   Reply With Quote
Old 05-04-2017, 01:00 PM   #9
Jstock85
Engine
Transmission
ECM / PCM
Gas Pedal
Overflow tank
Good luck,
Nick
Nick how are you mounting the stock overflow tank? I was considering the same. Just curious.
Old 05-04-2017, 01:36 PM   #10
69gmcc10
69gmcc10's Avatar
1989 blazer 24 gal tank under the bed with an 89 sending unit and a AC delco ep381 pump in the tank.
Old 01-07-2019, 12:55 PM   #11
faun_cee
Engine
Transmission
ECM / PCM
Gas Pedal
Overflow tank
Good luck,
Nick
I have an uncle ( who has never done an LS ) telling me I NEED to swap out the rear end or change the gears to not blow the rear end. is this true?
faun_cee is offline   Reply With Quote
Old 01-07-2019, 02:56 PM   #12
65blackfleetside
65blackfleetside's Avatar
What rear end are you running? stock chevy 10 bolt should be fine.
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B]
1965 fleetside Sold
65blackfleetside is offline   Reply With Quote
