05-03-2017, 03:06 PM | #26 |
Re: Strange vibration at 60 MPH and above.
Can't help with your issues, but that there is signature worthy.
Hook'em |
08-14-2017, 01:14 PM | #27 |
I have a similar issue with mine, it starts at 70 mph and gets worse as you accelerate. I'm almost positive it's the pinion bearing in my rear end. Although, I have heard things like accessory drive pulleys can cause this vibration as well.
Having just replaced my Harmonic balancer, belts and new Alternator, I'm leaning more towards my pinion bearings. I've bought all the required bearings,seals and crush sleeve to see if this remedys the vibration issue. Good luck finding your gremlin! Ben Smith
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
08-14-2017, 05:05 PM | #28 |
Do you have a smart phone? I know there are vibration analysis apps you can use. If we knew the frequency we can pinpoint the source easily.
08-14-2017, 06:02 PM | #29 |
I have an Iphone
08-14-2017, 06:32 PM | #30 |
"What's the frequency, Kenneth?"
08-14-2017, 06:39 PM | #31 |
Even though they "reclocked the drive shaft" doesn't mean a thing. It could still be 180 degrees out. Pull the complete shaft out and check the u-joints for any binding or sticky spots.
08-14-2017, 08:11 PM | #32 |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-14-2017, 08:39 PM | #33 |
08-14-2017, 10:31 PM | #34 |
Here is a cheap stab at diagnosis 101. The carrier may look and feel ok but under load may make it wobble. I could not tell on mine till I had the drive shaft and bearing assembly out. Nobody is perfect.
Next, Grease all the U-joints, drive and grease again. If you have no grease fittings on them replace them with a quality part with grease fittings. |
08-15-2017, 12:32 AM | #35 |
Who Changed This?
10-13-2017, 07:26 PM | #36 |
Did this ever get figured out? I have the same issue
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
10-14-2017, 10:55 AM | #37 |
Most of my vibrations were attributed to excessive carrier side bearing clearance,
I didn't have the side bearings shimmed tight enough. And the pinion preload wasn't sufficient as well. Vic here on the board(crusty,rusty,leaky,squeaky) gave me a hand setting it up. He happened to have a fixture that allowed him to check my housing to ensure that it wasn't bent, after that, it went together pretty straight forward from there. Have a good one! Be
11-24-2017, 12:27 PM | #38 | |
That software is $400 😳
71 c20 LWB |
11-25-2017, 09:18 AM | #39 |
Had similar vibration on my 71' C20. The problem was the right front shock had loosened at it's top mounting position. When it happened I had just hit 70 mph and thought I was going to die it vibrated so bad. I may be wrong but it's something to look at. it affirmed to me the importance of good, properly mounted shock absorbers.
