Old 05-03-2017, 06:56 PM   #1
lockled
2006 chevy hd 8 lug wheels
putting wheels on my 70 chevy longhorn with a 76 chevy 3/4 frt disc brake converison, rear is stock to vehicle?
who makes or has the lug nut conversion from metric to sae? and will I need to update the rear wheel studs to longer studs to install the caps?
will i need spacers for the rear also?
lockled is offline   Reply With Quote
Old 05-03-2017, 07:14 PM   #2
1968aj
Re: 2006 chevy hd 8 lug wheels
look on ebay. I think the lug nuts you need are sold by lug nut king and others.
1968aj is offline   Reply With Quote
Old 05-04-2017, 01:30 AM   #3
feller
feller's Avatar
Haven't bought them yet, but I did a Google search and found a place that sells them, standard inside with metric outside.
feller is offline   Reply With Quote
Old 05-04-2017, 11:15 AM   #4
FirstOwner69
FirstOwner69's Avatar
Since your front has been converted to discs, you probably have 1/2" studs on the rear and 9/16" on the front. Here are eBay links to sets of 32 of each size and a mixed set of 16 of each size.
http://www.ebay.com/itm/32-LUG-NUTS-...VWD11e&vxp=mtr
http://www.ebay.com/itm/302225984881...%3AMEBIDX%3AIT
http://www.ebay.com/itm/301886513765...%3AMEBIDX%3AIT
I'm not sure, but Longhorns may have always had Dana axles which normally require fairly thin spacers. If it has an Eaton, you are may be OK. Studs may be a tossup also.
FirstOwner69 is offline   Reply With Quote
