lowering c 10 with coil springs
1969 Panel .How much can I lower it with just cutting coil springs? Not looking for dropping much.Maybe 2 to 3" max and not dead set on that much. Doing it on cheap for now. RACE car not finished and it barely comes in second to breathing.LMAO All money is allotted to it.
Only the stupid know too much to learn something new. |
![]() Join Date: Jan 2011
Re: lowering c 10 with coil springa
You can cut half a wrap off the front and get it down a couple of inches. Problem is you cant cut the back they way they are wound. The only drop springs for suburban/panel are 4"
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
As PGSigns said, you can easily cut the front springs. I think the common drop is 2" per coil and you would be really pushing it to cut up to 2 coils, which would give you 4". I have 2 coils cut on mine and they ride fairly well (for an old truck) but you do have to cut out the bump stops for a 4" spring drop, so it's not for everyone. In the rear, your best bet is to just spend the 80 bucks on 2" drop block and longer U-bolts and you are done without messing with the springs.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
Cut between 1/2-1 coil in front for a mild drop. For the rear, I would opt for a small drop spring & 1-1.5" lowering blocks. Lowering blocks in truck-arm suspensions allow drop w/o affecting shock travel (which is good). 2" drop spring & lowering block combo should keep things level vs the front drop.
I am buying a Beltech 3 inch drop front spindle and would like to know what size rear spring would I need to level the truck out?
Typical front to rear rake is a 2" difference. Measure what you have now to know for sure.
Not to hijack but I have a question about cutting coils. I have a set of -2" front and -4" rear coils which I expect to set the rig level. I would like to maintain a 2" rake so my question is can I just cut a wrap off of the front coils? The reason I ask is because I haven't heard of anybody cutting lowered coils so I am wondering what the result would be. -4" up front?
#8 | |
That's a good thought that I hadn't considered. I had assumed that the unsprung length of the lowering coils would be the same and use a different rate to lower.
Typically, they're physically shorter.
I am uber disappointed! I purchased a pair of front lowering springs only to find that they were either cut OE coils or the aftermarket manufacturer copied a cut coil. WTH? I could have done this myself...
![]() Last edited by trailcarnage; 06-01-2017 at 08:50 PM. |
Re: lowering c 10 with coil springs
What were you hoping would be different about the lowered coils?
Happy to be here
![]() Join Date: Mar 2000
You are correct. And it would ride better as well
#15 |
![]() Join Date: Nov 2015
Where did you buy them ftom?
