Old 04-07-2004, 11:55 AM   #1
Swartzhund
need body mount help
I'm in the proccess of swapping the rusted shell off my 86 k10 with a much better 87 c10 donor. The body mounts came off the 86 pretty easy exept the cab. I tried an impact on the rear cab mounts and they wouldn't budge....ended up torching the hell out of them to cut them out.
My question is: If the ones on the donor are like this what is a good tip for getting them apart without cutting it apart?
Swartzhund is offline   Reply With Quote
Old 04-07-2004, 01:11 PM   #2
bigblock73
yeller
bigblock73's Avatar
Do you mean the body mount bolts?
bigblock73 is offline   Reply With Quote
Old 04-07-2004, 01:16 PM   #3
Swartzhund
yeah, but to torch the bolts I ended up burning the rubber mount and cutting into the cab support.
Old 04-07-2004, 01:21 PM   #4
bigblock73
yeller
bigblock73's Avatar
How about cutting off the bolt head, removing the cab, and taking the rest off when you have better access to them?
I have found that wd-40/liquid wrench, a propane torch, and a big breaker bar will loosen just about every stuck bolt. Working the bolt back and forth will help loosen it as well.
Old 04-07-2004, 01:23 PM   #5
Gibble
mmmm....Rye and Coke
Gibble's Avatar
A strong breaker bar, another bar to extend it so you have alot of leverage, and snap the bolts
Gibble is offline   Reply With Quote
Old 04-07-2004, 01:59 PM   #6
Swartzhund
I'll try that, I already broke an extension because I couldn't get the breaker bar in there without it. But that was all 3/8" stuff. I'll go bigger next try!
