Old 05-05-2017, 12:09 PM   #1
61memo
66 suspension short bed
Hello guys im faily new to the forum.I bought a 66 chevy shortbed all original and looking to soften my ride and doing a disk brake conversion on it any recommendations on what year newer chevy truck is best.Thank you
61memo is offline   Reply With Quote
Old 05-05-2017, 12:54 PM   #2
Clyde65
Clyde65's Avatar
Re: 66 suspension short bed
Disc brakes.
http://67-72chevytrucks.com/vboard/s....php?p=4450757
Making the truck ride softer, replace the springs and shocks( current shocks are probably bad)
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-05-2017, 04:21 PM   #3
JohnJ@RideTech
JohnJ@RideTech's Avatar
Make sure you get a brake kit that is compatible with a drum brake spindle OR you change out the spindle to one made for disk brakes. Don't want to end up with a brake kit you cant return!
I agree with Clyde65, a good set of shocks would do wonders. Are you planning on keeping the truck at its stock ride height?
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 05-05-2017, 04:52 PM   #4
61memo
The plan is to lower the truck.I am going to use a newer suspension(73-87) with 2 1/2 inch lowering spindels and 1 inch on coils.Besides 73 through 87 is there a newer chevy truck I can use? how about off a full size 5 lug Chevy Van? Thanks for the advice
Old 05-05-2017, 09:02 PM   #5
AcampoDave
AcampoDave's Avatar
A junk yard investigation with a tape measure showed me that vans have a wider track width but I don't know what make it that way.
AcampoDave is offline   Reply With Quote
Old 05-09-2017, 05:46 PM   #6
Muskwa
Check the sticky FAQ thread, lots of info on brakes and suspension.
Muskwa is offline   Reply With Quote
Old 05-10-2017, 12:05 AM   #7
Captainfab
60-66 Nut
The increased track width of the full sized vans is in the crossmember. The control arms are the same length as a C10 truck, but an '85 G20 van has different lower control arm shafts than a C10. I do not know how many years or applications use those LCA shafts.
Old 05-10-2017, 10:50 PM   #8
rvrfoot
Search is your best friend.
rvrfoot is offline   Reply With Quote
