Old 05-07-2017, 11:39 AM   #76
robozride
Re: Nina Patina 1953 3100 project.
Originally Posted by Desert1957 View Post
I really love the stance! Can you give me the info on the wheels and tires?
Size, offset , tire info.
wheels are 18x9.5 with 5" offset and 18x8 with 4"offset
Im not positive on the tires but im pretty sure the rears are 275x45 and the fronts are 245x40
robozride is offline   Reply With Quote
Old 05-07-2017, 01:33 PM   #77
HUSSEY
HUSSEY's Avatar
Your bed turned out great. Care to share what material you used and how you went about staining it?
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 05-07-2017, 02:01 PM   #78
robozride
Thank you! sure thing. I bought some rough cut cherry, cut and planned it down to size and then sanded it out nice and smooth. The stain is a "special walnut" and I applied two coats. I used latex spar varnish and applied 4 coats. color and grain match the patina well I think.
Old 05-08-2017, 08:12 PM   #79
lower50's
lower50's's Avatar
I like how your bed turned out.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-10-2017, 08:13 AM   #80
robozride
Thanks everyone for all of the responses. I'm getting really close but cant get much time in the garage. The engine did fire but fuel pump was bad.. Changed pump and carb wasn't working so there's a new one in the mail! Ive finished the wiring. I need to button up the interior, build a bracket for brake light switch and bleed the brakes, install new side glass and door seals, check all bolts and align front end... And out the door she goes. If only i could just get two good days and be left alone, lol soon though!
Old 05-15-2017, 08:21 PM   #81
robozride
Office Work...
Old 05-16-2017, 10:15 AM   #82
Desert1957
Desert1957's Avatar
What is that material you used for your kick panels and behind the seat? Looks good.
Desert
Desert1957 is offline   Reply With Quote
Old 05-16-2017, 04:17 PM   #83
robozride
I used FRP (fiberglass reinforced plastic) board from lowes and its covered with vinyl that matches the seats.
Old 05-17-2017, 11:55 AM   #84
lower50's
lower50's's Avatar
Nice Job!!!
1951 MG TD
Old 05-21-2017, 11:22 PM   #85
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Originally Posted by robozride View Post
Today was a good day in the shop, things are starting to come together. I installed the firewall booster/column mount, console, booster and finished up the steering shaft. I had to switch to an old set of headers I had as the steering wouldn't clear the coated ones I had planned. the booster mount is a nice piece but the brake pedal comes down on the right side of the column and wont work with the tranny hump, ill need to move it on the shaft or extend it over to the other side as there isn't room for a gas pedal. All in All though im happy with it all and now have steering. I think ill do the exhaust next? then I can throw the box back on.. stay tuned.
What did you use for the firewall mounted brake booster? Any more pictures on how it was installed?
Thank you
Sandemonium is offline   Reply With Quote
Old 05-22-2017, 07:20 AM   #86
robozride
Thank you
I got mine from CPP it is a fairly easy installation. Download template from website and drill 4 small holes and one 2". only issue that i had with it was it doesn't come with any bracket for a plunger type Brake light switch, fabbed that and am pretty happy with it
Old 06-04-2017, 03:27 PM   #87
robozride
Nina has been on her maiden voyage and is running good.. a few rattles to chase down and some tuning to dial in, finish up the interior and roll!
Old 06-04-2017, 10:55 PM   #88
oldman3
oldman3's Avatar
Looks great...Jim
oldman3 is offline   Reply With Quote
Old 06-05-2017, 01:51 AM   #89
iowaboynca
iowaboynca's Avatar
No video...don't believe you... Just kidding its looks good and i can imagine how good it feels
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 06-05-2017, 10:03 AM   #90
lower50's
lower50's's Avatar
Congratulations on your success it's a great feeling.
1951 MG TD
Old 06-13-2017, 07:41 PM   #91
robozride
Interior shook out pretty well I think!
Old 06-13-2017, 08:04 PM   #92
mongocanfly
mongocanfly's Avatar
Truck looks great...turned out really nice
Old 06-13-2017, 11:41 PM   #93
joedoh
joedoh's Avatar
interior came out gorgeous, I love ivory seats but they are so hard to keep clean.
Old 06-18-2017, 11:34 AM   #94
Scott2
Looks awesome! This is inspiration to get mine done.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 06-18-2017, 03:38 PM   #95
robozride
Just added this old "canteen" to my spare tire carrier. The jurys still out but I never liked having a spare on there and wouldn't change out the original stuff. what do you all think?
Old 06-18-2017, 03:53 PM   #96
mongocanfly
Neat idea..I never liked those side tire carriers either...would be neat if you could turn it into something useful ..tool box or something..
Old 06-18-2017, 06:44 PM   #97
Flysocal
Beer keg
Flysocal is offline   Reply With Quote
Old 06-19-2017, 10:03 AM   #98
robozride
Originally Posted by Flysocal View Post
Beer keg
Yeah, i really would like to get a Jack Daniels barrel 1/2 to put on there but can justify the $
Old 06-19-2017, 06:53 PM   #99
lower50's
lower50's's Avatar
Ya I like it
1951 MG TD
Old 06-19-2017, 10:51 PM   #100
joedoh
joedoh's Avatar
I will be the lone dissenter then, looks a little hokey to me.
