Old 05-14-2017, 11:55 PM   #1
custom10nut
custom10nut's Avatar
Scare bird brake parts?
Has anyone used Scarebird Brake Products?
I looked at their site, and for what I need (just the rotors and calipers), their kit might be the way to go.
The kit has the rotors, calipers, and the brackets to mount them.
The price is good and replacement parts are standard ones.
Any comments are welcomed
custom10nut is offline   Reply With Quote
Old 05-15-2017, 12:58 AM   #2
webfoot
Re: Scare bird brake parts?
Good stuff!
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 05-15-2017, 06:32 AM   #3
custom10nut
Great!
I like that they offer just the brakes, and not the whole PB system.
I've got everything (booster, MC, pro valve, etc.) else, so I didn't want to buy what I didn't need.
Old 05-15-2017, 08:19 AM   #4
clay68c10
clay68c10's Avatar
I used their parts for a front disc conversion on my caddy, good stuff and no problems. It's been 5 years and I would use them again.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-15-2017, 12:12 PM   #5
demian5
demian5's Avatar
I'll add to the positives as I have a kit on my 64 impala. Thinking of this route on my 70.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-15-2017, 12:57 PM   #6
dgheinen
Will their front disc brake work with a lowered truck? I assume so! But I don't want to guess. Previous owner installed drop spindles on the front but I am unsure of which ones.
Looking at product code SOC on their website.
dgheinen is offline   Reply With Quote
Old 05-15-2017, 02:42 PM   #7
demian5
demian5's Avatar
The rims matter, these wouldn't matter.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-15-2017, 07:13 PM   #8
custom10nut
Well then, it looks like it's time to order my disc brakes!
They say that good things come to those who wait, and I'll be doing a DB conversion for about $250 total.
Old 05-15-2017, 07:18 PM   #9
demian5
demian5's Avatar
Please report back here when you do and list the parts you needed including what master cylinder/combo valve you had to upgrade too.
Please also discuss the change out of the front brake lines and hoses and what was needed there as well.
Thanks in advance I think this is the way I will be going.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-15-2017, 11:30 PM   #10
custom10nut
Will do.
Old 01-26-2018, 01:36 AM   #11
andrewpclayton
andrewpclayton's Avatar
Did you do this? How did it go?
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 02-06-2018, 10:54 AM   #12
turbotruck
any update on this?
turbotruck is offline   Reply With Quote
Old 04-10-2018, 02:05 PM   #13
demian5
demian5's Avatar
I just ordered my brackets and getting parts next week. Including the brackets, all disc parts, master cylinder AND replacing upper and lower ball joints while apart, I'll be into the disc brake conversion $550.
You cannot beat that AND you get 3/4 ton front braking (when staying 6-lug).
Have fun with your $900 ECE or CPP kit without a master.
I'll do a write-up when I do the work.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-10-2018, 05:25 PM   #14
andrewpclayton
just remember the bearing sleeve is already in the rotor i was trying to pound what came with the bearing into the rotor on top of the one that is in there... thats probably a rookie mistake but I sure made it
Springfield Oregon
Old 04-10-2018, 07:07 PM   #15
demian5
demian5's Avatar
Originally Posted by andrewpclayton View Post
i was trying to pound the bearing into the rotor on top of the one that is in there... thats probably a rookie mistake
Full-on! LOL
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-11-2018, 12:06 PM   #16
OrngePeel
OrngePeel's Avatar
Like clay68c10, I used a Scarebird kit/setup for an older Cadillac(1940) I'm restoring and found that their parts were good quality and fit correct for what they had advertised. I was actually expecting to do the all too familiar routine of having to adapt or modify and alter to make the parts fit but they went right on and fit perfect without any trouble at all. One of the few times I can say that it actually worked without too much trouble.
OrngePeel is offline   Reply With Quote
Old 04-14-2018, 11:30 PM   #17
cornerstone
cornerstone's Avatar
So pardon my ignorance, but I went to their site and couldnt find parts for a c10. I want to convert to rear disc on my 72, and dont know if the brackets Is that the same thing as a "midsize"
cornerstone is offline   Reply With Quote
Old 04-15-2018, 10:35 AM   #18
Jason Banks
Jason Banks's Avatar
This setup really isn't that much less expensive than buying the replacement spindles. You still need calipers/rotors/pads/hoses/bearings. Of course if you are staying 6 lug you need to get the slightly more expensive 6 lug rotors. I paid $215 delivered for the spindles and $129 delivered for the 6 lug rotors. I then bought my bearings, calipers, hoses, pads and a new master/booster combo. I also spent $50 delivered for the backing plates, which won't work with the scarebird...
Jason Banks is online now   Reply With Quote
Old 04-15-2018, 10:27 PM   #19
cornerstone
Do you have any experience with rear conversion for 5 lug?
Old 04-15-2018, 10:39 PM   #20
Jason Banks
I would order these axles - https://www.amazon.com/gp/product/B005TDQ9OY/
and these bearings - https://www.amazon.com/gp/product/B0078U83CM/
I didn't catch what year truck you have though. Make sure you need the narrower 30.5 inch axles...
edit: you should probably get some wheel studs too...not sure which ones.
