#776 | |
Re: How about some pics of Static Dropped C-10's
I am glad they don't look underneath at shows. Mine is a driver and gets as many miles as I can on the weekends. |
#777 | |
#778 |
Uh oh spoke too soon. I just measured mine with a tape measure, I only have 2 inches now. With blocks I'll have about a half inch.
#779 |
That's what I ordered but I never checked them. Just installed them. Are you sure you have 5 inch springs?
#780 | |
#781 | |
#782 |
Well crap, you cant trust anyone. This is my first C10 I have ever lowered or built so I didn't even question what they sent me. Being it was almost 3 years ago I am not even sure who I bought them from anymore. I will double check my spring measurement again.
![]() I am hoping to install mid length headers and then look at lowering more and will have to address it then. For now it sits the way its is . I like the stance now and I cant do much about complaining, I guess I should checked what was shipped better. Lesson learned the hard way ![]() |
#783 |
I've read (can't remember where since it's been so long ago) that there are different heights being sold as the same drop by different manufacturers. It would be like brand X selling a 5" drop spring that sits a bit higher than a brand Y spring. So just because you have a 5" drop spring, it's not necessarily going to be the same as the other guy's 5" drop spring.
Also, keep in mind that suspension settles over time, so a 5" drop spring that's been installed for a few years will be lower than a brand new 5" drop spring from the same company. It could be one manufacturer says the spring is a 5" drop when it's brand new (ultimately ending up with more drop) or the other guys say their spring is a 5" drop after the suspension settles in (starts out less than 5").
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#784 |
Good point thank you.
#785 |
*edit* I posted a question but saw that it was answered a few posts above. I am in for the discussion, however, because I am interested in the measurements you guys are taking. I've been trying to find references for rear to frame, and spring compression measurements with drop springs. Thanks!
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#786 | |
Dan. Drivetrain parts and accessories. 68 medium green shortbed fleetside |
#787 |
From the very little experience i have with designing my own custom suspension and doing research 4" of up travel is basically all any road going vehicle typically has. 4" is an industry standard basically. As long as your springs are the correct Spring Rate for your application and your shocks are good you should never bottom out with 4" of up travel. That being said i believe the diff will hit the bed floor before the axle hits the frame with the bump stop cut off. So watch out.
#788 |
![]() Join Date: Dec 2015
Re: static drop pics
#789 |
4 1/2 front and 6 3/4 rear
Front suspension: Early Classic Enterprises 2 ˝” Drop Disc Brake Spindles Early Classic Enterprises 2” Drop Springs ‘68 Chevy C10 Sway Bar, Energy Suspension Urethane Bushings Moog Bushings, Ball Joints and Steering Linkage. AGR Power Steering Gear Box Bilstein Monotube Shocks Frame and Chassis: Stripped Bare and Painted Epoxy Satin Black POL Trailing Arm Crossmember with adjustable mounts for pinion angle setting. CPP C-notch kit Rear Suspension: ’72 Chevy C10 12 Bolt Rear End 2:76 gears. CPP 5” drop springs CPP 1 1/2” drop blocks CPP adjustable track bar Bilstein Monotube Shocks Stitch welded trailing arms Energy Suspension urethane trailing arm bushings Z28 rear sway bar Wheels and Tires: ’72 Chevy 15x6 stock steel wheels Hanook Optimo H724 Whitewall P215/75R15 tires '68 Chevrolet car stainless COPO hub caps
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
#790 |
Before
#791 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#792 |
All I did was polish, polish and then polish it again. It probably hadn’t ever seen wax, before me.
#793 |
Very nicely done Glenn!
Romans 10:9 - The Truth |
#794 |
#795 |
#796 |
A guy with a truck
Very nice truck!
#797 |
JKK that truck is awesome!
#798 |
5 7 drop
#799 |
I'm looking at an old post of the 72, can you share the size and backspacing of the wheels and also tire size. Awesome look and perfect stance
1966 Custom Cab SWB SBW Fleetside 1968 C10 BBW SWB Fleetside |
#800 |
awesome truck. Can you please share the size rims, tires and backspacing? Love to duplicate this look on my 68
