Old 05-17-2017, 01:55 PM   #1
Poop du Jour
New to the C10 game, need advice on a rear drop
Just picked up a 78 C15 and I'm itching to drop it on its face but I see that the previous owner removed all but 4 leaves from the rear spring pack. It's also still above the axle. The goal for this is to keep it super cheap and ride it dirty so my question is this: flip kit or drop shackles?
5-6" further drop seems like it might be too low but 2" might not be enough. Front coils will get cut down too. It needs to be as low as possible, I don't care about ride quality.
Thanks y'all!
Poop du Jour is offline   Reply With Quote
Old 05-17-2017, 02:30 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: New to the C10 game, need advice on a rear drop
If you want it low, then flip the rear. Use a drop spindle and a cut spring in the front. Some of these trucks only had 4 or 5 leaves in the spring pack from the factory.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-17-2017, 05:15 PM   #3
Jstock85
cutting one coil should give you about a 2" drop. other guys can tell you for sure
Jstock85 is offline   Reply With Quote
Old 05-17-2017, 09:29 PM   #4
bbbc10
Diggin The SquareLife
If you dont care how it rides just heat the front and rear springs ������
bbbc10 is offline   Reply With Quote
Old 05-17-2017, 11:17 PM   #5
Jaysonb
Jaysonb's Avatar
Nice looking truck! I like the color combo.
Jaysonb is offline   Reply With Quote
Old 05-18-2017, 07:11 AM   #6
riz
DON'T do a hack job like cutting coils or heating the springs...... if you're gonna do it, do it right. It's cheap to lower one of these so why do a hack job ???
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 05-18-2017, 08:49 AM   #7
Keith Seymore
Keith Seymore's Avatar
Cut coils in the front, relocated spring hangers in the rear. Total cost was $1.38 for bolts and a front end alignment.
250,000 and 30 years as a daily driver with no issues.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-18-2017, 09:05 AM   #8
Jstock85
K
Thats my kind of mod$$$ Cutting coils is no problem. What or how did you relocate the hangers? Would you mind sharing a few pictures?
Old 05-18-2017, 10:12 AM   #9
Tash4
Tash4's Avatar
There is a guy on here that sells a bracket for the rear for under $50 that drops it 5in in back. specialtyretail i believe is his name. i used them and they work awesome. they are in the 73-87 sales section.
Tash4 is offline   Reply With Quote
Old 05-18-2017, 10:27 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm there with you. His brackets are cheap and simple.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-18-2017, 11:52 AM   #11
aggie91
aggie91's Avatar
OMG, your back. Hope all has been well with you.
Karl
The LST Challenge:
Old 05-18-2017, 12:48 PM   #12
Keith Seymore
You have to cut the rivets (somewhat labor intensive) and replace them with 3/8" Grade 8 bolts.
http://67-72chevytrucks.com/vboard/s...d.php?t=509224
If you go this route I can talk you through it.
More discussion here:
http://67-72chevytrucks.com/vboard/s...d.php?t=323014
K
1979-1986
1986 - 2019
Old 05-18-2017, 01:17 PM   #13
Jstock85
yeah i def plan on doing that. Did you have to replace the shocks afterward?
Old 05-18-2017, 01:54 PM   #14
Keith Seymore
No.
K
1979-1986
1986 - 2019
Old 05-18-2017, 05:08 PM   #15
Tx Firefighter
Hey Karl. I'm good. I've been creeping your thread over on LS1Tech for a long time now. I hope you can make it to C10s in the Park this year.
Old 05-18-2017, 07:44 PM   #16
RDrancher
RDrancher's Avatar
Well you Shady Rascal you...
I'm on board with Specialty Retail's brackets. Inexpensive and they work just fine.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 05-19-2017, 12:04 AM   #17
Jstock85
i think ill give keith's method a shot first. lower my truck for $1.38! gotta be worth a shot
Old 05-19-2017, 01:50 AM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Several dollar's in bolts some $20 axle pads.
And a few hours
Clipped 2 coils, cut bump pads off the lower A-arm and rear frame.
Flipped the back.
Longer bolts in the upper A-arm
How we did it before we knew about drop spindles.
Still rolling this way today.
Old 05-19-2017, 07:47 AM   #19
Jstock85
Im glad you guys shared this info. I knew there had to be a better way to get low than theses $500-$600 "lowering kits"
Old 05-19-2017, 09:43 AM   #20
Tx Firefighter
You figured it out.
One guy is nice and kind. The other one has a curious eye twitch and mutters ugly things under his breath.
Come find me at Decatur swap meet this fall and shake my hand.
Old 05-19-2017, 10:50 AM   #21
RDrancher
RDrancher's Avatar
You figured it out.
Yep, pretty much figured it out during your answering of one of my pm's, but I wasn't 100% sure and kept my mouth shut. The instagram id is a bit of a dead-horse giveaway though.
I'll see you there.
Old 05-19-2017, 11:59 AM   #22
lolife99
67-72 parts collector,…
lolife99's Avatar
Diggin the truck and the Cragars!
Keith
Convert to disc brakes.
Old 05-19-2017, 12:13 PM   #23
Tx Firefighter
Thanks Keith.
The wheel and tire setup is about to be switched out honestly. It doesn't drive the way I want it with the 215/75 235/75 combo. The fitment isn't exactly what I want either.
You're a perceptive guy. I'd bet money you can guess what's in the boxes.
Old 05-19-2017, 12:37 PM   #24
lolife99
lolife99's Avatar
Looks like you are switching to another classic design,...
Keith
Old 05-19-2017, 01:18 PM   #25
Tx Firefighter
Wider wheels. Wider tires. And attempting to disguise the track width difference some. My front track width is pretty noticeably wider than the rear. It seems much more so than any other truck I've done. It finally weighed on me enough to do something about it.
