05-17-2017, 01:55 PM | #1 |
New to the C10 game, need advice on a rear drop
Just picked up a 78 C15 and I'm itching to drop it on its face but I see that the previous owner removed all but 4 leaves from the rear spring pack. It's also still above the axle. The goal for this is to keep it super cheap and ride it dirty so my question is this: flip kit or drop shackles?
5-6" further drop seems like it might be too low but 2" might not be enough. Front coils will get cut down too. It needs to be as low as possible, I don't care about ride quality. Thanks y'all! |
05-17-2017, 02:30 PM | #2 |
I'm just glad to be here!
Re: New to the C10 game, need advice on a rear drop
If you want it low, then flip the rear. Use a drop spindle and a cut spring in the front. Some of these trucks only had 4 or 5 leaves in the spring pack from the factory.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-17-2017, 05:15 PM | #3 |
cutting one coil should give you about a 2" drop. other guys can tell you for sure
05-17-2017, 09:29 PM | #4 |
Diggin The SquareLife
If you dont care how it rides just heat the front and rear springs
05-17-2017, 11:17 PM | #5 |
Nice looking truck! I like the color combo.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
05-18-2017, 07:11 AM | #6 |
DON'T do a hack job like cutting coils or heating the springs...... if you're gonna do it, do it right. It's cheap to lower one of these so why do a hack job ???
RIZ 81 C10 short box 82 K5 Blazer |
05-18-2017, 08:49 AM | #7 |
Cut coils in the front, relocated spring hangers in the rear. Total cost was $1.38 for bolts and a front end alignment.
250,000 and 30 years as a daily driver with no issues. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-18-2017, 09:05 AM | #8 |
Thats my kind of mod$$$ Cutting coils is no problem. What or how did you relocate the hangers? Would you mind sharing a few pictures?
05-18-2017, 10:12 AM | #9 |
There is a guy on here that sells a bracket for the rear for under $50 that drops it 5in in back. specialtyretail i believe is his name. i used them and they work awesome. they are in the 73-87 sales section.
05-18-2017, 10:27 AM | #10 | |
Watch out for your cornhole !
05-18-2017, 11:52 AM | #11 |
OMG, your back. Hope all has been well with you.
05-18-2017, 12:48 PM | #12 |
You have to cut the rivets (somewhat labor intensive) and replace them with 3/8" Grade 8 bolts.
http://67-72chevytrucks.com/vboard/s...d.php?t=509224 If you go this route I can talk you through it. More discussion here: http://67-72chevytrucks.com/vboard/s...d.php?t=323014 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-18-2017 at 01:20 PM. |
05-18-2017, 01:17 PM | #13 |
yeah i def plan on doing that. Did you have to replace the shocks afterward?
05-18-2017, 01:54 PM | #14 |
No.
K
05-18-2017, 05:08 PM | #15 |
Hey Karl. I'm good. I've been creeping your thread over on LS1Tech for a long time now. I hope you can make it to C10s in the Park this year.
05-18-2017, 07:44 PM | #16 |
Well you Shady Rascal you...
I'm on board with Specialty Retail's brackets. Inexpensive and they work just fine.
Romans 10:9 - The Truth |
05-19-2017, 12:04 AM | #17 |
i think ill give keith's method a shot first. lower my truck for $1.38! gotta be worth a shot
05-19-2017, 01:50 AM | #18 |
At the body shop.
Several dollar's in bolts some $20 axle pads.
And a few hours Clipped 2 coils, cut bump pads off the lower A-arm and rear frame. Flipped the back. Longer bolts in the upper A-arm How we did it before we knew about drop spindles. Still rolling this way today.
" That didnt make it any newer " " Dont antique the equipment " |
05-19-2017, 07:47 AM | #19 |
Im glad you guys shared this info. I knew there had to be a better way to get low than theses $500-$600 "lowering kits"
05-19-2017, 09:43 AM | #20 |
You figured it out.
One guy is nice and kind. The other one has a curious eye twitch and mutters ugly things under his breath. Come find me at Decatur swap meet this fall and shake my hand.
05-19-2017, 10:50 AM | #21 | |
I'll see you there.
05-19-2017, 11:59 AM | #22 |
67-72 parts collector,…
Diggin the truck and the Cragars!
05-19-2017, 12:13 PM | #23 |
Thanks Keith.
The wheel and tire setup is about to be switched out honestly. It doesn't drive the way I want it with the 215/75 235/75 combo. The fitment isn't exactly what I want either. You're a perceptive guy. I'd bet money you can guess what's in the boxes.
05-19-2017, 12:37 PM | #24 |
Looks like you are switching to another classic design,...
05-19-2017, 01:18 PM | #25 |
Wider wheels. Wider tires. And attempting to disguise the track width difference some. My front track width is pretty noticeably wider than the rear. It seems much more so than any other truck I've done. It finally weighed on me enough to do something about it.
