05-21-2017, 02:28 AM | #26 | |
Re: Zinc Plating Shop Recomendation
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
05-21-2017, 01:21 PM | #27 |
i have ordered lots of them bolts from the bolt barn -always use them when i remove the spring hangers and clean up the frame rust& repaint ! i have a big bolt bin i keep stock w/ lots of differant sizes -the locking nuts are great & the flange heads are the cats meow !!! i used to work for a chassis shop & we always "cad " plated the narrowed rear axles housings -had lots of walk in lookers that thought they was "gold "plated ????
05-21-2017, 11:40 PM | #28 |
That hardware is real nice ghalperin. At the time I'm a slave to the original hardware, but yeah, those are super.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-02-2017, 12:58 AM | #29 |
Last week I got all my parts back from Arrow Plating. I've been busy putting my truck together. They did a great job. I only had on minor issue, I had them plate my rusty radiator mounts and the bead blasting killed them. It was my own fault, I know that you shouldn't bead blast rusty sheet metal, if you don't want the pits to be craters. I could post a photo, but it just looks like new shiny nuts and bolts.
06-02-2017, 07:10 AM | #30 |
Watch out for your cornhole !
That's a relief to hear the report card on Arrow Plating's work. Even though they have been fantastic for me for years, when I recommended them and you spent some real coin using them I was fingers crossed that everything turned out up to your standards. It's a shame folks can't go there in person. They are real nice folks.
06-02-2017, 10:34 AM | #31 |
Thanks again for the recommendation.
Although not a closeup, here are the U-bolts, washers and nuts, spring cups and the diff cover bolts. Plated hardware really help it look finished.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 06-02-2017 at 10:40 AM. |
06-02-2017, 11:00 AM | #32 |
Finally clicked on this thread a little skeptical about why bothering to re zinc old hardware ... daaaamn ***k looks awesome !
M.A.G.A. |
06-02-2017, 02:17 PM | #33 |
Very nice!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
