Old 05-08-2017, 10:22 AM   #1
bluetrim
The double nickel
I reckon I better start a build thread so I'll have a place to ask all my questions. This was a Craigslist find a few months ago. I bought a 55 when I was a kid and have been wanting another one ever since. Shoutout to joedoh for the info I've received so far. Lot's of inspiration from the build threads on here.
To summarize my previous thread, I bought a kit from Matts Classic Bowtie that included Shockwaves and a 4 link set up. After installing the front shocks it was clear the previous owner installed the camaro clip higher on the frame in order to lower the truck. This caused the Ridetech stuff not to fit.
I decided to take it on the chin and redo the front clip.
Original clip job..
Looking better....
4 link done
bluetrim is offline   Reply With Quote
Old 05-08-2017, 01:12 PM   #2
joedoh
joedoh's Avatar
Re: The double nickel
looking great!
Old 05-08-2017, 01:17 PM   #3
Indian113
Indian113's Avatar
Nice Job on the reclip! I'll bet it set pretty low the first time. I love your Truck always had a soft spot for the TF trucks.
Indian113 is offline   Reply With Quote
Old 05-20-2017, 10:55 PM   #4
bluetrim
Got the lq9 in last week. I'm super stoked. I haven't decided if I want to keep it stock or make it go gee bloopa gee bloopa yet .
I bought it sight unseen so kind of fitting of the column and steering wheel that came in the truck...
Came with pedal and stand alone harness. Every wire was labeled.
New 4l60
Old 05-20-2017, 11:18 PM   #5
59chev
59chev's Avatar
Subscribed. What are your plans for it?
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 05-21-2017, 08:12 PM   #6
59chev
59chev's Avatar
Did you drive it much before you reclipped it? Did it seem too low with the stock camaro springs in it? I am aiming for a similar stance at ride height and I'm curious if I can accomplish that with cut springs or if I will need to bag mine. Did you go with the shockwaves because you wanted to lower it more or was it to have the option of raising it up from the previous ride height?
Old 05-22-2017, 06:42 PM   #7
bluetrim
It would rub the tires when i turned. I got into a situation in traffic where i needed to make a tight turn and couldn't. The rear was a bigger problem. Every time i hit a bump it would bottom out. I went with Ridetech because i wanted the adjustability but mainly because i wanted a good ride and heard that regular bags didn't have that good of a ride. I guess I'm about to find out if it was worth it. That was one of the things I feared because I couldn't find a lot of reviews on the shockwaves.
Old 06-02-2017, 10:50 PM   #8
bluetrim
I got these for dirt cheap last week. Does anyone know what adapters i need in order to make them fit my current wheels?
Here are the wheels I have
Old 06-03-2017, 12:05 AM   #9
joedoh
joedoh's Avatar
rally caps wont fit wheels with nubs. rally caps mount inside the lug recess, nub wheels need caps that mount outside. they make 10.5" poverty caps for nub wheels, not that look like those but some nice ones. or you can buy 15" smoothie wheels from wheel vintiques and the poverty rally caps will fit them.
the two likely reasons why the rear wont lift high enough on your airbar is probably 1. shocks and 2. setting it up at ride height. for shocks, I like usuing new JK jeep take offs, they have like 9" or so of travel, the airlift kit shocks only have 4.5. for the ride height, sleeve bags will lift like 7.5" but if you arent setting the bag up to squish completely where its aired out, you will waste lift and it will ride poorly.
Old 06-07-2017, 05:08 PM   #10
bluetrim
so smoothies from wheel vintiques or rallys are the only option?
Old 06-07-2017, 05:24 PM   #11
joedoh
joedoh's Avatar
they are the only wheels those caps fit, yes. no one makes an adapter to put them on nub wheels.
full disclosure they will also fit wheel vintiques artillery
Old 06-07-2017, 07:50 PM   #12
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by joedoh View Post
.... no one makes an adapter to put them on nub wheels....
While this may be technically true there may well be a way to do it if you're handy with a drill and hammer. Check out these hubcap clips on your wheels. The "nubs" would show -which you may not like - but you won't know until you test fit them. -Dan
As you can se below, there are ways to mount these even on rims for which they were never made. At $2 each it's not like it's gonna cost you much to give it a try.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-08-2017, 08:10 PM   #13
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool project, keep posting!!
ChuckDriver is offline   Reply With Quote
Old 06-09-2017, 01:01 PM   #14
lower50's
lower50's's Avatar
Cool truck! Are you going to use a ride height controller or go from air pressure?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-10-2017, 06:54 AM   #15
47 Fasttoys
47 Fasttoys's Avatar
"i wanted a good ride and heard that regular bags didn't have that good of a ride" Actually standard bags will ride just as good as factory suspension if set up correctly and the proper size bag is used. I run 8" bags on my truck (1500 chassis) an if you didn't know I was on air ride you you couldn't tell it by ride quality. The key is proper set up, I have seen and ridden in a lot of hack jobs that rode like crap. Ride teck is a good system and easy to get a good ride but it is costly.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 06-25-2017, 08:17 PM   #16
bluetrim
I bought the Ride Pro kit from Ridetech
Old 06-25-2017, 08:23 PM   #17
bluetrim
F body pan is on.
Sanden compressor and bracket.
Dirty Dingo LS Mounts.
where to post images
Old 07-14-2017, 09:28 PM   #18
bluetrim
Having trouble mounting the frame mount booster and m/c. Tranny crossmember is in the way. Anyone have pics of a frame mount booster with a 4l60? Preferably with the exhaust mounted but that may be asking too much.....
Old 07-17-2017, 10:36 PM   #19
joedoh
joedoh's Avatar
looking good! I changed a pan gasket with the motor hanging from the cherry picker before, its like wrestling with a pig.
Old 07-21-2017, 04:46 PM   #20
RockinKees
RockinKees's Avatar
Lots of good work done so far!
I follow along!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 07-21-2017, 05:13 PM   #21
bluetrim
Old 07-23-2017, 10:56 PM   #22
focusedontheprize
focusedontheprize's Avatar
Looking good!
focusedontheprize is offline   Reply With Quote
Old 08-01-2017, 08:43 PM   #23
bluetrim
Got the LQ9 fired off.....
http://www.youtube.com/watch?v=wt__N...ature=youtu.be
Old 08-01-2017, 08:48 PM   #24
bluetrim
Tried to embed the video and did it exactly how I posted the one above (by just deleting the s in https) and this time it didn't work. I give up
Old 08-01-2017, 09:42 PM   #25
mongocanfly
mongocanfly's Avatar
soundn good
