![]() Join Date: Aug 2009
New Shocks Necessary With 1.875"/2.0" Lowering Springs?
Ordered a pair of Hotchkis 1.875" front springs, and will be buying a pair of 2" or possibly 3" rear springs (any suggestions for performance rear springs?). Do I need new shocks with either?
Thank you. |
Re: New Shocks Necessary With 1.875"/2.0" Lowering Springs?
New shocks are a definite yes. You should also install shock re-locaters in the rear. When you lower the rear, it changes the angle of the shock and takes away its ability to do it's job.
#3 | |
Is it something that I need to do all at once, or could I get away with the existing shocks for a few thousand miles on the 2" springs? |
![]() Join Date: Feb 2016
Not being familiar with the Hotchkiss springs are these a two inch drop? If so then new shocks are not required, but there are affordable good choices that will be a large improvement over the stock ones. For the rear using drop blocks instead of springs will work very well plus the shock geometry will not be changed so no need to change mounts. If you do the drop and drive it a hundred miles or so then do the shocks you will see what each contributes to the package.
Just my two cents worth. You results may vary.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5 | |
