05-26-2017, 07:09 PM | #26 |
Re: A/C factory or Aftermarket
05-26-2017, 07:10 PM | #27 | |
With the parallel condenser I almost think the AC is "too good", challenging the cooling system on a hot day.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-26-2017, 07:11 PM | #28 | |
05-26-2017, 07:45 PM | #29 |
Also Scotts72, check out this video. It gives a good reason to open up the housing and remove the evaporator as part of getting an unkown system up and running. It's what I find in many of the ac units I restore.
https://youtu.be/CQdXlwr5lwg |
05-27-2017, 09:48 AM | #30 |
Yes, I have a factory system that some parts were rebuilt, recalibrated or refurbished by Classic Auto Air in Tampa, FL. Is there a crossflow or parallel flow condenser available for 67-72 Chevy pickups? I was not aware anyone was making one. I have one in my 72 Cutlass and my 70 Bonneville and they work GREAT! Vent air never exceeds the 30s. The two cars use the same condenser...only the mounting is different, but they are too big for the truck because of the hood latch.
05-27-2017, 04:34 PM | #31 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-28-2017, 11:16 AM | #32 |
yep flushing and pressure testing the evap is a also a must in my opinion as they can look damn near brand new on the outside. Ive pressure tested who knows how many and some that looked great externally would leak.
05-28-2017, 09:24 PM | #33 |
Old member
The Classic air I put in my dad's 56 had to have both a manual valve and the vacuum valve installed before it would cool down. It blows 38* now with no problems.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-28-2017, 11:35 PM | #34 |
What I hear from a good source, if you're looking to sell a real nice truck, aftermarket may be the way to go. Younger truck fans prefer an "updated" version, probably with lots of chrome & such.
Depends on the buyer and truck. Personally I prefer original-ish. I plan on a R134 conversion & rebuilt compressor.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-28-2017, 07:08 PM | #35 |
I want to buy a condenser for a 72 c10 how in the world do i post on the parts page?
08-28-2017, 07:57 PM | #36 |
You have to be a subscribing member.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
08-24-2019, 03:02 AM | #37 |
I,d run the stock setup and charge it with propane. Works far better than r12 and costs about 1 dollar................ Lots of u tube how toos there also.
I BELIEVE IN JOHN 3:16 |
08-24-2019, 10:05 AM | #38 |
Moderator
Nothing works better than r12 in a factory system...since that is what it’s designed for. You can’t get any better than 36 degrees Monkey around with it just to save a buck and you are just chasing your tail. Everybody talks about “do it once, do it right” with most everything else automobile related, but that seems to go out the window when it comes to AC.
08-24-2019, 10:39 AM | #39 |
93 chevy motorhome....last of the r12 systems...compressor went bad( sanden like the aftermarket kits use)...couldnt find a new one that came with the proper oil for r12 and didnt want to disassemble a new one to properly clean it...so new compressor, new barrier hoses, new reciever drier and new expansion valve...removed and flushed everything else, evacuated with 6cfm pump...and used 134....system is no way as cold as it originally was...sure it drops 20 degrees from ambient temp and is technically functioning properly but the volume of air inside the camper is so large that it never recirculates progressively colder air so the best it puts out is about 60 degrees...shouldnt be an issue in a pickup with a tiny cab...i cant even go for a parallel condensor cause the bottom half of mine is also the engine oil cooler...so i regret the conversion and was warned it wouldnt be as efficient by a friend who does auto a/c but saw many people on line swear that their conversions would freeze you out so i figured id try...and i still have plenty of r12 and a source to buy it
1970 short step c10 leaf spring 454 |
08-24-2019, 10:51 AM | #40 |
Hi
I like the original look if possible I am from alberta Canada There were very few trucks up here with a/c any time I see one with factory a/c I think it looks so good and it adds value to the truck I have just bought a 1972 highlander with factory a/c but the compressor was removed. I went to reinstall it and I am missing a few brkts. Does any one have a/c brkts for sale or tell me where to get them |
08-24-2019, 01:51 PM | #41 |
its clear you haven't tried propane
