Old 05-27-2017, 09:19 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
1972 Big Block engine and parts
Back after a long break to sell remaining parts. Updated as of 5/9/2020 to reflect what I have for sale now.
1972 396/402 engine (longblock minus intake) with 41,000 miles. Had stuck lifter so assume you'll need to rebuild. 500 or 700 with intake and valve covers/wire loom pieces
1972 Th400 transmission with 41,000 miles. Unknown condition. Includes torque converter.
PS Pump with all brackets and bolts/washers/nuts 220
Alternator brackets with all bolts/washers/nuts 120
BB pulleys 150 (A/C and smog parts gone)
Air cleaner with spark arrestor and factory wingnut 120
Original radiator (LEAKING) $40
BB Flywheel 40
BB factory valve covers (have dents) with Wire loom pieces 50
BB Factory correct date intake with choke and water neck 100
BB wiring harness still flexible and complete 100
Everything for 1000
These parts are also for sale locally and local pickup preferred to shipping.
Shipping is extra and will be calculated by part or group of parts purchased.
Old 05-27-2017, 09:26 AM   #2
67kid
Originally Posted by VA72C10 View Post
PS Pump with all brackets and bolts/washers/nuts 250
Alternator brackets with all bolts/washers/nuts 160
BB pulleys 175
72 BB motor mounts with clamshells and all bolts 220
Air cleaner with spark arrestor and factory wingnut 150
4 core rad mounts upper and lower with rubber and hardware 80
BB fan shroud 100
Original radiator (LEAKING) $60
Heat riser (tube good- bottom shield is rusted) 30
BB factory valve covers with Wire loom pieces 80
BB Factory correct date intake with choke and water neck 140
Heat shield for cab 40
I will take the tube and valve covers do you have pics
67kid is offline   Reply With Quote
Old 05-27-2017, 11:36 AM   #3
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Got it. I'll post pictures by tomorrow or Monday at latest.
Old 05-27-2017, 03:02 PM   #4
72chevynut
72chevynut's Avatar
Question Re: Big Block parts
Put me in line for the heat riser tube.
Michael
72chevynut is offline   Reply With Quote
Old 05-27-2017, 10:48 PM   #5
Eagle9502
Re: Big Block parts
Is the radiator a Harrison? Any pics?
Eagle9502 is offline   Reply With Quote
Old 05-28-2017, 09:48 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Got it
Yes,
Old 05-28-2017, 10:47 AM   #7
67kid
I will take the tube and shield any pics of valve covers and is the smog setup for sale?
Old 05-28-2017, 12:42 PM   #8
72chevynut
72chevynut's Avatar
Re: Big Block parts
I will take the fan shroud pending pics.
Michael
Old 05-28-2017, 12:43 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Shield as in heat shield? Just confirming.
I'll get a picture of the valve covers off later.
Old 05-28-2017, 12:47 PM   #10
67kid
Does the rusted shield go with tube? Is the smog setup for sale? and also interested in pulleys is the water pump 3 groove
Old 05-28-2017, 12:48 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Have all clips and hardware. One blemish shown on closeup.
Old 05-28-2017, 12:51 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Yes, there's only a little over half left but yes, it's included. Was thinking you meant the exhaust heat shield.
Yes, pulleys are for AC and smog so three. Smog setup is sold.
Old 05-28-2017, 02:13 PM   #13
72chevynut
72chevynut's Avatar
Re: Big Block parts
I will take it, please PM payment info. Thanks
Michael
Old 05-28-2017, 03:37 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
Okay, let me get a box for it and figure up a cost for shipping.
Old 05-28-2017, 03:45 PM   #15
72chevynut
72chevynut's Avatar
Re: Big Block parts
Sounds good, zip code is 40353. Thanks
Michael
Old 05-28-2017, 08:35 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Pretty sure I have the other wire separator still attached to the plug wires.
Old 05-29-2017, 12:35 AM   #17
67kid
Re: Big Block parts
Hard to tell from pics any dents?
Old 05-29-2017, 01:08 AM   #18
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
I don't think there are any dents. I'll check tomorrow.
Old 05-30-2017, 05:52 PM   #19
67kid
Re: Big Block parts
will take the tube how do you take paypal?
Old 05-31-2017, 01:07 PM   #20
missionstreettattoo
missionstreettattoo's Avatar
Re: Big Block parts
do you still have the alternator bracket and is it for the drivers side?
missionstreettattoo is offline   Reply With Quote
Old 05-31-2017, 04:15 PM   #21
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Yes, I take PayPal. Will try to fit in a flat rate box to save on shipping. Can you give me your zip so I can confirm and get you a total? Thanks.
Old 05-31-2017, 04:15 PM   #22
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block parts
Yes, and yes. It's the correct factory side brackets. It has several brackets and all the hardware.
Old 05-31-2017, 05:59 PM   #23
67kid
Re: Big Block parts
zip is 85203 still interested in valve covers if dent free shipping on those?
Old 05-31-2017, 09:20 PM   #24
missionstreettattoo
Re: Big Block parts
i do not know what the correct side is, only that my truck was a straight 6 with a fresh installed BBC and the alternator lead is only long enough to reach the drivers side. which hoes for mounting does this use? i am very interested
, just want to make sure it will work for the application I need it for. Thank you!
Old 06-05-2017, 09:57 AM   #25
67kid
Still for sale?
396, 402, big block
